Old 01-04-2005, 07:58 AM
Scott Will's Avatar
Scott Will Scott Will is offline
Default perfect rivet, nuts and bolts storage?
Spent all day yesterday driving around town trying to find the perfect storage solution for all the RV fasteners. Even went to the zen of all storage places, The Container Store, but found nothing that really stands out.
Has anyone found a great storage solution?
First I thought a bunch of those cheap Glad "Take Along" small bowls (8 for $1.99 or something like that) would be ideal - they are similar to baby food jars. But holding all those bowls with somewhat of an odd shape isn't that easy. Couldn't find anything that would carry/store a bunch of bowls. Nor could I find plain baby food jars... without resorting to eating 50 jars of yummy blended peas.
Then I ended up getting 3 Stanley Pro Organizers from Lowes. They have removable compartments which is cool but they have no lid. No fun when you have to pick up 400 3/32 rivets.
Thanks for any and all ideas!
Scott
7A QB
Old 01-04-2005, 08:18 AM
N916K's Avatar
N916K N916K is offline
Just get one of those racks that have a bunch of small sliding trays. I found that a container that you have to open a lid causes all kinds of trouble. When you mess up its all your rivets not just one size. Also get a small tray and put just enough rivets in it so you don't spill the whole lot while working.
I've never had to pick up a bunch of rivets, I have swept them up though
Old 01-04-2005, 09:00 AM
oldsfolks oldsfolks is offline
Red face Perfect Rivets,Nuts & Bolts Storage
I use a couple of the 60 drawer plastic storage units. Rivets are labeled on front of drawer in ascending order and styles are seperate. Bolts ,nuts , pop rivets , etc. the same way. Take a drawer or two along to the work location and just be careful to not spill - picking up AND sorting is exasperating.
Bob Olds RV-4 ( Twice )
Old 01-04-2005, 09:11 AM
Davepar's Avatar
Davepar Davepar is offline
I use the small drawer units as well. Easy to pull out a bolt here and there, easy to remove a whole drawer of rivets to take over to the work area. I admit I have had a few spills, but I'd rather suffer through picking up a few rivets than dealing with a lid.
I started with one unit on the empennage, added a unit for the wings, and added another unit for the fuselage. It's also very easy to reorganize drawers to keep all the rivets in one area, bolts in another, etc.
Dave
Dave Parsons, Seattle, WA, RV-7A, sold
www.dualrudder.com/rv7 - building blog
RunwayFinder.com - airport info, online charts, live METARs, TFRs, etc.
Old 01-04-2005, 10:23 AM
akarmy's Avatar
akarmy akarmy is offline
I use 2 different types of boxes. For bolts and pop rivets I use something like this: Parts Bins
For rivets I use: Tilt Bins
The tilt bins work great for taking the bins of rivets to the bench with you, and you can select different sizes depending on the volume of goods you need to store. The holders mount on the wall, or can be stand alone.
Andy Karmy
Covington WA
RV-8 - Flying!
RV-9A - sold
Dec 2020 Paid
Old 01-04-2005, 11:41 AM
admin admin is offline
Administrator
Red face
Just FYI, you can insert the actual pic if you want of the bins. Look for the yellow square with a mountain drawn in it when you are composing the message. You probably knew this, but in case you didn't...
Doug Reeves
Editor: www.VansAirForce.net
Owner: Delta Romeo, LLC.
