Go Back   VAF Forums > Regional Forums > California
Old 01-31-2017, 10:33 PM
Piloto506 Piloto506 is offline
Default Hangar in TOA or CPM (Torrance or Compton)
I will have my RV4 in about a month and a half and are looking for someone that would like to share a hangar at either Torrance or Compton airport.
The other option is to rent one. I have the opportunity to rent a hangar at either Torrance or Compton right away as well but again would like to find someone that would be interested in sharing as they are in the $500 monthly range.
Contact me via PM or Text/tel 2139257992
RV-4 @ CPM
Old 02-01-2017, 07:51 AM
xavierm xavierm is offline
Default Cheapest you'll find
CPM has the cheapest hangars you will find in the area. It's a friendly airport and more relaxed than TOA although you can't go wrong based at either airport.
EAA Chapter 96 (AT CPM) has hangar space available which is lower cost.
Meetings are the third Saturday (Feb. 18).
you can find out more about the hangar space here:
http://www.96.eaachapter.org/hangarspace.htm
_____________
Xavier
RV-7 build in progress
www.theaviatorx.com
"Genius is persistence in disguise"
Old 02-01-2017, 10:02 AM
Most definitely. I would love to be in Compton just would like to offset some of the costs by sharing it with another plane. I plan on joining the local chapter as well for sure.
RV-4 @ CPM
Old 02-04-2017, 10:01 AM
Ended up renting a T-hangar at CPM. I will be joining the local chapter as well so that should be fun. I was a member previously but never really active.
The hangar will be empty for a couple of months in case anyone needs a temporary space until I can bring my plane over as it is currently in TX.
Also still looking for anyone interested in sharing preferably a smaller plane, high wing, canard, or ultralight as the hangar is 1,000 sf, 40' wide, 35' deep.
RV-4 @ CPM
Old 06-28-2021, 09:34 PM
WELD WELD is offline
Hey Piloto506,
I'm in a similar situation as you were a few years ago.
I'm looking for a hangar to build my RV.
Probably only need a partial hangar for that.
I live north of LAX and SMO doesn't allow any building and in general are trying to kick everybody out so there is less resistance before they close up in 2028.
Hawthorne would be the closest but I assume they are more expensive, still looking for a contact there to check out T-hangar prices.
After that CMP would be the next candidate.
Do you know what current T-hangar prices are at CMP?
Maybe know if there are any empty ones at all?
Or do you have a contact for me to ask?
Any help is appreciated!
Thank you so much in advance!
Old 06-29-2021, 01:52 AM
davidkarlsberg davidkarlsberg is offline
The trick with SMO is that you are NOT building an airplane. You are building a metal sculpture! Prices are 50% market rates because SMO refuses to rent hangars to aircrafts. Tell the leasing office you are an artist looking for space to build a sculpture and you will be surprised with the price. You can't do phase 1 at SMO anyways so you will be stuck going to chino or camarillo and if it doesn't have an airworthiness certificate it's not an airplane
Los Angeles
RV-7 Builder
www.davidkarlsberg.com
Old 06-29-2021, 08:16 PM
Mike6A Mike6A is offline
Default Hangar
Hawthorne won’t be affordable. Was based therefor 20 years until they kicked us out, tore down our hangers and turned it into Citationheaven. Four of us moved to emt and found plenty of space. 4rvs on the field and one building a rv14. I have a 43x36 hanger for $707 a month and share with a car collector. I live in Westminster and on weekend mornings it is a 35-40 minute drive. gGood luck
Old 06-29-2021, 09:37 PM
@Davidkarlsberg That is an interesting approach. I usually prefer to be honest but I guess I can make an exception for people that try to keep planes out of hangars Also as you said, its a sculpture until its airworthy.
I will facepalm if they suddenly say:"sorry we only lease out to aircraft owners and builders" hahaha
@Mike6A Thank you for that information! I guess I try compton before I try EMT, merly bc of distance from me.
Old 06-30-2021, 12:44 AM
You don't have to worry about that! They will not rent hangars to aircraft anymore because they are not "compatible with the local community". I have both a hangar at SMO and HHR and I agree with the other comments about HHR being too expensive now.
Los Angeles
RV-7 Builder
Old 06-30-2021, 08:49 AM
Weld, if you choose EMT I know a car guy that would split a hanger with you. $350 month is cheap in Los Angeles. The guy building his 14 lives in Brentwood.
