Old 02-26-2007, 03:47 AM
FlyingArcher's Avatar
FlyingArcher FlyingArcher is offline
Default Tip: Show us your cowl / hinge pin cover or method to secure pin
Hello RVers,
I need some help trying to find out a link to a series of pictures I've seen some time ago, showing how different builders had solved the problem of securing the cowl hinge pin. I think the pictures were taken at some fly-in, but I can't relocate the page, even after googling with different keywords.
Maybe the author of this page will read this...
Thanks a lot
Daniel Mouly
VAF #778 - [2013 payment done]
RV-9A Emp. & Wings 95%, Fuse 70%
Austin Healey 3000 MKIII fully restored
LFCD (Andernos Les Bains), France
Construction Log comments in French (not really up to date, sorry)
Old 02-26-2007, 03:54 AM
hevansrv7a's Avatar
hevansrv7a hevansrv7a is offline
Default What's around the firewall?
Are you using hinges or "skybolts" around the firewall?
H. Evan's RV-7A N17HH 240+ hours
We can lift ourselves out of ignorance, we can find ourselves as creatures of excellence and intelligence and skill. We can be free! We can learn to fly!" -J.L. Seagull
Paid $25.00 "dues" net of PayPal cost for 2015, 2016, 2017 and 2018 (December).
This airplane is for sale: see website. my website
Old 02-26-2007, 05:06 AM
Default Not for a VAN's
Sorry I didn't mention that at first, but my question is not for a problem I'm trying to fix on my -9A project, but for another one where I'm part of a builders team for a Jabiru J400.
The top and low cowls are joined with a hinge, like on standard VAN's cowls, and I'm trying to bring some examples of how to secure the hinge pin to my teammates.
I'm far far away from reaching that step on my -9A
Daniel Mouly
Old 02-26-2007, 09:14 AM
f1rocket's Avatar
f1rocket f1rocket is offline
Default Here's Mine!
Randy Pflanzer
Greenwood, IN
www.pflanzer-aviation.com
Paid through 2043!
Lund fishing Boat, 2017, GONE FISHING
RV-12 - Completed 2014, Sold
427 Shelby Cobra - Completed 2012, Sold
F1 EVO - partially completed, Sold
F1 Rocket - Completed 2005, Sold
RV-7A - Partially completed, Sold
RV-6 - Completed 2000, Sold
Long-EZ - Completed 1987, Sold
Old 02-26-2007, 10:36 AM
JonJay's Avatar
JonJay JonJay is offline
Default Van's Prewelded Hinge pin tab
Stock product from Van's.
RV6 - Builder/Flying
Bucker Jungmann
RV1 - Proud Pilot.
Old 02-26-2007, 06:19 PM
walter's Avatar
walter walter is offline
see entry dated 3/24/05 here:
http://rv7-a.com/lasttenpercent.htm
and this page:
http://rv7-a.com/last_5_percent.htm
I'm really happy the way they turned out. You hardly notice them.
Walter Tondu
Flying RV-8A - Fastback, IO-390, G3X Touch, 74 HRT
Prior RV-7A Build Log
Old 02-26-2007, 06:48 PM
Rosie's Avatar
Rosie Rosie is offline
Location: I live in on the Rosamond Skypark (CA) and am married to Victoria (Tuppergal).
Hinge Pin retainer pictures from my buddy Rick Gray's award winning RV-6 Rosie
Paul A. "Rosie" Rosales
Rosamond Skypark (L00), CA
RV-6A, 4200+ hours since 7/4/2000
Old 02-27-2007, 12:03 AM
ksouthar ksouthar is offline
Default Hinge Pins
I could send you a picture of mine but you wouldn't see the cowl hing pin tab!
My cowl pins are inserted from inside the fuselage.
A short piece of 3/16" stainless brake line is inserted though a small hole in the firewall that is aligned with the hinge and extends into the cabin. The line acts as a guide for the pin and is epoxied in place in the firewall and a clamp holds the other end in place in the cabin.
The pin is inserted from the cabin, through the brake line and then into the hinges. A little pushing and twisting on a plastic knob that is epoxied on the end of the pin allows it to slide right through the hinges and into place.
Extra care is needed when the hinges are attached to the cowling to ensure the hinges don't bind later. Grind the pin end to a dull point so that it slides into the hinge more easily.
I had heard from other builders that this technique would require two people to install the cowling (one to position it in place and the other to install the pin from inside the cabin). Not so...... If care is taken during the installation of the hinges, installation or removal of the cowling top is a one-person task.
Keith
N355RV
RV9A
10 months flying......
Old 02-27-2007, 03:17 PM
hevansrv7a's Avatar
Default Mine are hidden but differently
Mine are inserted from the aft edge by pulling out the sides a little. There's a right angle bend in each one at the back end. When they are fully inserted I close up the rest of the cowl along the firewall with skybolt style fasteners. I did not want a hole in the firewall, so this is all done externally. The bent leg clears the camlock but is stopped by it so it cannot work back and thus below the flange. Removal is accomplished with a wire loop on a bolt shank. Pics and details on request. I don't think it's any different, but it's a SJ cowl.
Old 03-01-2007, 04:19 PM
Default Thank you!
Thanks a lot for all your answers. I just had a message form our builders team leader, and after reading many comments on this forum, it seems that we'll go for Camlocs
I think this is the way I'll also choose when it's time for me to work on that part of the project.
For now, I've just played with the tools by building the RV Training Project and the nice Toolbox, waiting for a replacement for some empennage parts that have been damaged during transportation to France
At least I could buck my first bad rivets on test metal...
Cheers
Daniel Mouly
