  #11
Old 04-15-2021, 06:20 PM
abwaldal@gmail.com abwaldal@gmail.com is offline
Another thing you may find is the paint is all messed up when the brake reservoir leaks as mine did and didn't know it till I pulled up the carpet and the foam padding. (I didn't build this one) The T-fitting came loose at the back of the reservoir and dribbled all down the firewall. I had only had to add a small amount of fluid a couple of times in 3 years.
A whole bunch of paint was all curled up under all that.
The takeaway is if the carpet and what ever is under it isn't easily removeable for inspection the paint doesn't so anything but add weight. The bare aluminum looks great though.
I'm not repainting the bare areas.
My three cents worth. Art
Old 04-16-2021, 05:52 PM
Jeff Vaughan's Avatar
Jeff Vaughan Jeff Vaughan is offline
No primer on mine. Primed the heck out of my 7. Went as light as possible on the 12
Jeff Vaughan
RV 12 N237VW ELSA
RV 7A N561EV Sold
West Chester Pa
2021 donation current
Old 04-16-2021, 07:30 PM
E. D. Eliot E. D. Eliot is offline
Default Paint
My 12 is zinc chromate primed and a good rattle can finish over that. It will be flown near the ocean a lot. When I started the 12 build, I weighted 236 - now weigh 175. My goal is 165. I did this for health reasons. I'm 71" tall. I don't expect to have the fastest, best looking or best 12 in the fleet but I hope that my 12 and I last a long and happy time.
Building finally
Old 04-16-2021, 08:25 PM
Roadjunkie1's Avatar
Roadjunkie1 Roadjunkie1 is offline
Default Aircraft....and...um...fuselage weight....
CONGRATULATIONS on the weight loss! That is significant! I am a competitive cyclist and one of the best ways to go faster is reducing the weight of the "engine:".
An interior that is primed with a light coat is not going to add that much weight to the aircraft and will make it last longer. Come pop some inspection hole covers in a few airplanes with me if you want to see the result of not being primed.
RV-12: Good choice for a long and happy future!!
Michael
RV-4 2860
1946 C-90-8 J-3 Cub
The adventure begins when things stop going as planned - Glen Heggstad
Subscriber!
