Old 04-11-2021, 04:34 PM
JohnBruns JohnBruns is offline
Default Elevator Gusset Rivet/Hole Size.
I am working on my RV-10 elevators. I have a question about hole size for the E-921 Elevator Gusset. Page 9-6 step 4 says to final drill with a #30 drill. Page 9-11 step 6 and page 9-14, step 2 indicate AN470AD4-4 rivets. However, my E-921 Elevator Gussets, E-1007 Rear Spars and E-905 Root Ribs were delivered with final size holes—no orange markings and I have confirmed the hole sizes. The holes in the Elevator Gussets and matching holes on the Rear Spars and Root Ribs are all #40 and match perfectly.
Should I match drill these holes to #30? Or are the plans a little behind the new parts process?
John Bruns
Education and Recreation
Learning a lot and still having fun!
John Bruns
RV-10
Learning a Lot and Still Having Fun!
Old 04-11-2021, 06:00 PM
Mike S's Avatar
Mike S Mike S is online now
Senior Curmudgeon
Default Welcome to VAF
John, welcome aboard the good ship VAF
Mike Starkey
VAF 909
Rv-10, N210LM.
Flying as of 12/4/2010
Phase 1 done, 2/4/2011
Old 04-12-2021, 07:27 AM
alumley alumley is offline
I'm assembling my second elevator now. I forget if I had to final drill the gusset or not but I definitely used -4 rivets to attach the gusset to both the root rib and rear spar so go ahead and final drill those 4 holes #30. Note that the root rib attaches to the forward and aft spars with -3 rivets so don't drill out those holes! But the gusset is definitely -4.
Andrew
Ontario, Canada
Building an RV-10
Old 04-15-2021, 07:28 AM
Thank you. I appreciate the advice. Up-sized and match drill the holes to #30.
John Bruns
RV-10
