Old 04-17-2021, 10:05 AM
DanH's Avatar
DanH DanH is offline
Originally Posted by vlittle View Post
To be more specific, crimp terminals should meet MS25036 specifications. Both Amp (TE) PIDG and Molex AVIKRIMP brands meet this specification.
Insulated ring terminals should meet MS25036. There are similar milspecs for other connection styles and for uninsulated terminals.
Dan Horton
RV-8 SS
Barrett IO-390
Old 04-17-2021, 09:59 PM
calpilot calpilot is offline
I have dual "P" mags with 9:1 pistons, performance cam, ventury cut seats, etc. I run BR9ES plugs, a bit cooler. NGK plugs of the same number, ie
BR8ES can come with screw on caps or solid caps. If the screw on caps get loose, it will cause radio noise, and burn areas on the plug end connector of the spark plug wire. Will run rough at altitude. Using the solid plug caps and new terminal ends, runs great!!
DAR Gary
Old 04-18-2021, 07:08 AM
vlittle's Avatar
vlittle vlittle is offline
Righto, badly worded. I'm trying to point out that both PIDG and AVIKRIMP brands are acceptable for various terminals and that they meet milspecs.
Thanks, Vern
V e r n. ====
RV-9A complete
Harmon Rocket complete
Member of OnSpeed team
The VV in huVVer.tech
Victoria, BC (Summer)
Chandler, Az (Winter)
Old 04-18-2021, 07:28 AM
GalinHdz's Avatar
GalinHdz GalinHdz is offline
Originally Posted by Walt View Post
Hate to disagree but Solder sleeves are made for terminating the shield on shielded wire not joining wires.
This video shows how to join wires together using "solder sleeves", the original design idea.
Galin
CP-ASEL-AMEL-IR
FCC Radiotelephone (PG) with Radar Endorsement
2021 Donation made
www.PuertoRicoFlyer.com
Old 04-18-2021, 08:09 AM
Walt's Avatar
Walt Walt is offline
Ya Gotta love youtube...
https://www.youtube.com/watch?v=unxEdyW8RP8
Never seen a 'solder sleeve' called out for a splice repair in any document I've ever seen. On the other hand I have repaired a few bad/cold solder joints where this method was used for a CAN bus and a few other things.
Just the fact that it would take me 10x longer and 3 hands to do what an amp butt splice can do in seconds with 100% reliability is a good enough reason not to use it.
Walt Aronow, DFW, TX (52F)
EXP Aircraft Services LLC
RV7A built 2004, 1900+ hrs, New Titan IO-370, Bendix Mags
Old 04-18-2021, 08:46 AM
GalinHdz's Avatar
FWIW I also prefer a butt splice but solder sleeves can and do work.
BTW, awesome "thread drift".
Galin
CP-ASEL-AMEL-IR
2021 Donation made
Old 04-18-2021, 09:41 AM
rv8ch's Avatar
rv8ch rv8ch is online now
Default 3 hands needed
The 3 hands part is my main complaint - you think you have it stable, put the heat gun on, and it all moves.
Mickey Coggins
http://rv8.ch
"Hello, world!"
Old 04-18-2021, 09:37 PM
Aggie78 Aggie78 is offline
Default E-Mag Install Manual
From the "Maintenance" section of the E-Mag manual:
Every annual or 100 hour inspection:
6. Examine control plug and coil plug connections. Tighten to 4-5 inch pounds. Verify there are no stray wire strands. Verify all control wires use the Adel clamp strain relief.
The control plug needs an eyes-on every time the cowl comes off, IMO. I have a short list of things like this I look at each time it does on mine. Just to be sure.
I like the ferrule idea...neat....clean...secure.
Rob S.
Rob Schroer
RV-7/N75WV
YIO-360-M1B
New Braunfels, Texas (KBAZ)
VAF Monthly Donor
