Old 04-01-2021, 11:37 AM
riseric's Avatar
riseric riseric is offline
Default Same here...
Originally Posted by Draker View Post
Here's a gotcha for builders going with the horizontal air induction system snorkel. If you follow the directions on installing the baffles, you'll end up with a beautifully trimmed set of baffles, including the front-left inlet ramp (CB-1002A). Then, when you go to install the snorkel, you'll notice step 1 says "NOTE: Do not trim the length of part 2 Left Front Inlet Floor at this time". Of course they are talking about one of the baffle parts you just trimmed. Save $25+shipping by not trimming that piece.
I did exactly the same...
I have a beautyfully trimmed CB-1002A that fits perfectly to the cowl, but it's too short now...
Thinking about a way around it, maybe by adding a doubler to increase its lenght???
Eric,
2021 dues happily donated
RV-8 slow built #83274
Grove Airfoiled Gear, Wheels & Brakes
VPX-Pro, EFII System 32, EarthX batteries
Aerosport IO-375, MTV-9-B/183
Skyview HDX
C-GEMQ
Almost done...
Old 04-01-2021, 12:05 PM
jcarne's Avatar
jcarne jcarne is offline
Don't be surprised if you have to go a little off script in this area. My snorkel was a little outboard which changed the screw pattern and a few other things up. Just do something that makes it work and the baffles can seal against. You could go to a bigger length to get it like the plans but it may include modifying the snorkel for starter clearance.
Checkout post 534 here.
Jereme Carne
PPL
RV-7A Flying as of 03/2021
Exempt but gladly paying!
Old 04-01-2021, 01:31 PM
riseric's Avatar
Thanks Jereme for the link to photos, it really helps!!
I notice that your CB-1002A is also short so there,s no front "lip". And you put an angle below the front filter overhang.
Did you you leave that as is??
Eric,
Skyview HDX
C-GEMQ
Almost done...
Old 04-01-2021, 02:51 PM
jcarne's Avatar
Yep, it's flying just like you see in the pictures. Seems to be working quite well. I did put some RTV in the corners so the baffle material could seal a little better as it forms a radius right there. Don't worry about bending the filleted piece of metal like it shows in the plans, if it's horizontal induction that piece gets eliminated as you can tell.
Jereme Carne
PPL
Old 04-01-2021, 03:04 PM
wirejock's Avatar
wirejock wirejock is offline
Default Panel platenut strips
Ok. Don't make this mistake. These two strips (photos) are riveted to the top skin. They each have platenuts for screws holding the panel. They are not symmetrical with respect to the screws but they are symmetrical to the rivet holes so they can be installed on the wrong sides. Yep. Did it. They were riveted some time ago. Windshield is long since installed. So imagine my frustration when I try to attach the panel and there's no platenuts behind 10 holes! Oh Bother!
I drilled out the platenuts. Fabricated a doubler strip and attached the platenuts in the correct locations.
Do as I say. Don't do as I do!
Click image for larger version
Larry Larson
Estes Park, CO
wirejock at yahoo dot com
Donated 01/01/2021, plus a little extra.
Empennage, wings, fuse, finishing kit, now FWF
Disclaimer
Old 04-01-2021, 05:02 PM
Freakshow108's Avatar
Freakshow108 Freakshow108 is offline
Attachment 9913
Attachment 9914
I’m attaching theses this weekend. Thanks for the heads up!!
Old 04-16-2021, 03:39 PM
wirejock's Avatar
Default FWF lines
Probably not a gotcha but I wish I had listened to my friend Jereme and deleted all the oil and fuel lines. Granted I'm off reservation with the RV10 oil cooler mounted on the firewall but the VA-136 fuel line is not a good fit with the new mount and gear. I wish I had relocated the contactors toward the starboard side. I'm sure Vans has a reason for them located so close to the fuel line.
So, as usual, Tom @ TS Flightlines to the rescue. In addition to a nice conversation, we swapped some photos and measurements and new lines are on the way. Thanks Tom.
Larry Larson
Estes Park, CO
Disclaimer
Old 04-16-2021, 05:05 PM
jcarne's Avatar
You won't regret it. I used em for all my lines. P.S. You can also get your data plate and fuel caps engraved by Steve when the time comes if you want.
Jereme Carne
PPL
Old 04-16-2021, 05:46 PM
wirejock's Avatar
Default Panel cut
Next phone call. He also cuts panels. Tom said he would send a draft CAD drawing to fine tune then cut the panel to the final drawing. Saves me drawing from scratch.
Larry Larson
Estes Park, CO
Disclaimer
Old 04-16-2021, 07:09 PM
PilotjohnS PilotjohnS is offline
Default Real homebuilder
Only real homebuilders make their panels with a drill and file.
John S
WARNING! Information presented in this post is my opinion. All users of info have sole responsibility for determining accuracy or suitability for their use.
Dues paid 2021, worth every penny
RV9A- Status:
Tail 98% done
Wings 98% done
Fuselage Kit 98% done
Finishing Kit 35% canopy done for now
Electrical 85% in work
Firewall Forward 5% in work
Fiberglass 0%, thought i was building in metal?
www.pilotjohnsrv9.blogspot.com
