Old 04-17-2021, 11:57 AM
jrock836's Avatar
jrock836 jrock836 is offline
Default Rollbar Paint
So the builder of my RV12 clearly didn't properly prep the rollbar for paint and it's flaking off. I don't have a paint sprayer and don't really want to pay a painter $$$$ to make it look better..
What do you guys think? Do you think I would have any luck with taping everything off, sand it down and clean it really well, and then spray primer and paint from a rattle can? Give me an idea of what I (inexperienced painter) could do to make this look better and not break the bank.. Or will I probably just make it look worse and should just leave it alone?
Thanks!
Joe
RV-12 N49DD - ELSA #120566
LSRI-A
EAA #1409566
Hawkins Airstrip - Godley, TEXAS! ( 35TT )
Private Pilot since '79!
Old 04-17-2021, 02:13 PM
JwWright57 JwWright57 is offline
One option is to sand it down and cover it with some vinyl. Like carbon fiber look, etc.
Jeff Wright, Charlotte NC
Rv-12 started!
Tail 99% done
Wings 99% done
12IS fuse kit 99% done
Finish kit 95% done
Avionics kit 1% done
Dues paid 2020
Old 04-17-2021, 02:27 PM
Piper J3's Avatar
Piper J3 Piper J3 is offline
^^^^ What he said ^^^^
3M 1080 Silver Vinyl. Really easy to install...
Name:	Screen Shot 2021-04-17 at 4.23.25 PM.jpg
ID:	10507  Click image for larger version
Name:	Screen Shot 2021-04-17 at 4.22.26 PM.jpg
ID:	10508  Click image for larger version
Name:	Screen Shot 2021-04-17 at 4.21.45 PM.jpg
Jim Stricker - EAA #499867
Bought Flying RV-12 #120058 Oct 2015 with 48TT - Hobbs now 650
Old 04-17-2021, 03:01 PM
Mask everything around it.
Sand it down to remove the flaking paint and any rust.
If you have everything really well masked, spray prime it, if not, prime it with a foam roller or brush and an appropriate primer.
Then, either vinyl wrap it or paint it the same way you primed it.
Kyle Boatright
Marietta, GA
2001 RV-6 N46KB
2019(?) RV-10
Old 04-17-2021, 04:20 PM
wirejock's Avatar
wirejock wirejock is offline
Default Vinyl
Agree. Sand it and vinyl wrap it.
Prep for paint won't be a big job but masking everything and removing the canopy is a lot of work. Overspray will go everywhere and possibly damage the canopy.
Cabon fiber vinyl would look cool!
Larry Larson
Estes Park, CO
wirejock at yahoo dot com
Donated 01/01/2021, plus a little extra.
Disclaimer
Old 04-17-2021, 05:02 PM
jrock836's Avatar
Thanks.. I like the vinyl wrap idea! I've never worked with that stuff.. Guess I'll head to youtube and watch some install videos..
Joe
LSRI-A
EAA #1409566
Old 04-17-2021, 07:20 PM
DHeal DHeal is offline
If you have the original-style Lexan rear window be extra careful that you do not allow any solvents or harsh cleaning chemicals near the raw cut edge of the Lexan -- crazing may result.
David Heal - Windsor, CA (near Santa Rosa)
EAA #23982 (circa 1965) - EAA Technical Counselor and Flight Advisor; CFI - A&I
RV-12 E-LSA #120496 (SV w/ AP and ADS-B 2020) - N124DH flying since March 2014 - 1,030+ hours (as of May 2021)!
VAF donation through June 2021.
