  #11
Old 04-29-2018, 08:10 PM
VA Maule VA Maule is offline
Green gunk is most likely fule dye, probably would be a good idea to blow it out.
Maule MXT-7(daily flyer)
Lancer 235(partner)
Raidial RV-8R Ephanage Done, Wings Done, Fuselage on it's tall Grove gear & engine hung
Old 04-29-2018, 08:27 PM
Steve Melton's Avatar
I was thinking oil but fuel is more likely, to your point.
Steve Melton
Cincinnati, OH
I was born an airplane nut. I have no explanation for it.
www.rvplasticparts.com
Old 04-30-2018, 08:38 AM
rvsxer rvsxer is offline
After having my carb heat door assy wear badly I replaced my carb heat cable with a button-lock cable, an Aircraft Spruce A-700. When the carb heat is off, the door is now tight against the housing and doesn't vibrate. That has really helped.
The button-lock cable will also hold a partial heat setting for carbureted lean-of -peak operation.
Mike Hilger
RV-6 N207AM w/G3X, 1,800 hours +
South St. Paul, MN (KSGS)
A&P, EAA Tech Counselor
We're all here because we're not all there...
Old 04-30-2018, 10:16 AM
My non-RV has an ARB Carb Ice Detector from Spruce. It reliably tells me when ice is beginning to form. Small amounts of carb heat can clear it at that point, so your locking cable is a good idea.
Thanks!
Dave
Old 11-18-2018, 08:52 AM
Default 700 hrs - no detectable wear on linkage
seems to be holding up well. all original except for cotter pin. baffle mat'l has slight wear on the pilot side.
Steve Melton
Cincinnati, OH
Old 04-27-2019, 08:39 PM
Default 750 hrs no detectable wear
everything looks good.
Steve Melton
Cincinnati, OH
Old 07-22-2020, 09:54 PM
Default 850 hrs
no wear that I can detect by hand.
Steve Melton
Cincinnati, OH
Old 07-28-2020, 09:10 PM
gmcjetpilot's Avatar
gmcjetpilot gmcjetpilot is offline
Exclamation
I ended all the issues with the wire Push Pull cable by going to a cable with a threaded end. I use a rod end fitting. No Mickey Mouse issues. This is an important control and this isn't a place compramise.
George
Raleigh, NC Area
RV-4, RV-7, ATP, CFII, MEI, 737/757/767
2020 Dues Paid
Old 01-17-2021, 06:10 PM
dbegeman's Avatar
dbegeman dbegeman is offline
What did you use to replace the push pull cable? I have had problems with my carb heat cable (wore out the hole in the door lever and now the cable broke).
Dan
RV-6A N60KD
Navy Vet
Donation made for 2020
Old 01-17-2021, 07:01 PM
my cable and everything else here is original. 850 hrs. no wear. perfect condition.
Steve Melton
Cincinnati, OH
