Old 01-19-2021, 02:13 PM
David Carter David Carter is offline
Default Guidance on completing 8130.6 for change from fixed-pitch to constant-speed?
Can anyone provide guidance on how to use the new AWC Portal online system to update the FAA registry branch records for changing from fixed-pitch to constant-speed?
The Atlanta FSDO approved my Phase 1 flight test plan late last year. The inspector did not yet have access to the AWC, so we did it all via email. Vic installed the new prop, and I have flown the test program & signed it off in the logbook. (Loving the new Hartzell composite!)
However, I'm stumped on how to complete the paperwork. I started an application in the AWC Portal using the "amended certificate" option, but it's not clear to me how to complete it. The lookup field for the prop model says that the model G2YR/N7605W-2X is not found. It does let me continue with that value entered. I was not sure what to enter in the Certification Basis section. It won't let me proceed without filling in the AD compliance fields, even after I check "not applicable" at the bottom.
Assuming I get past that screen, the next unknown I think will be what documents do I need to attach?
I conversed with Joe Norris via private message (thanks Joe!). He has not run into this question yet with the new system so he is checking with his FAA contacts. He & I agreed I should post the question here to see if anyone else has helpful input, and so we can document what we find for others to benefit from in the future.
David
RV-7A Slider N87BP (bought flying in 2018)
Superior XP-IO-360, Hartzell G2YR/N7605W-2X
AFP Fuel Injection & Dual SDS CPI-2 ignition
KLZU - Lawrenceville, GA
2020 Dues Paid
Old 01-19-2021, 06:07 PM
arffguy arffguy is offline
Default New Airworthiness Certificate needed?
Okay, I'm confused.
Wouldn't this just be a (major) change that puts you back into Phase One? Revise aircraft logs, weight and balance and aircraft manual only?
Edit: Thanks David. I learned something new. A link to Mel's article in Kitplanes magazine.
https://www.kitplanes.com/ask-the-dar-92/
Mike F
RV-6A wings/fuselage
RV-3 empennage (extra thanks to Mr. Zilik)
RV-4 Plans only S/N 2938
Cessna 152
Elk Grove, CA
VAF #744 Exempt but paid anyway
Old 01-20-2021, 08:18 AM
jnorris's Avatar
jnorris jnorris is offline
First, before we get too far down this road, make sure your aircraft's operating limitations actually require such a records update. This requirement came into being just a few years ago, so older operating limitations will not contain the requirement. Look at the major change provisions in YOUR aircraft's operating limitations, and follow that procedure. Do not "mix and match" operating limitation requirements.
So, IF your aircraft's operating limitations specifically require that the aircraft's records at OKC need to be updated when changing from a fixed-pitch to constant-speed propeller (or vice versa), or from a reciprocating to turbine engine (or vice versa) you need to file an updated 8130-6 form.
This is NOT a new application. Do NOT run it through the AWC system or your local FAA office. This is simply a records update. I have verified with FAA that you simply need to mail the updated -6 form directly to the FAA Aircraft Registration Branch at the following address:
P.O. Box 25504
Oklahoma City, OK 73125-0504
I suggest you make a copy of the form before sending it, and sending it by such means that you get a delivery confirmation. Keep that for your records so that you have proof that you followed your major change requirement.
Make sure you follow all the other requirements for incorporating a major change as well. Again, read YOUR operating limitations and follow the procedure therein. Do not do anything without verifying the correct procedure for YOUR aircraft.
Cheers!
Joe
Old 01-20-2021, 08:42 AM
jpneal jpneal is offline
Very timely post! Literally going through this right now as well. Thanks for the info.
Joe Neal
RV-7 (N87DX)
VAF - Dues current 1/1/2021
Old 01-21-2021, 07:48 AM
Super Moderator
David, thought we discussed this. No need to go through the AWC. Just mail 8130-6 to FFA OKC for a records update.
Vic
Vic Syracuse
www.Baselegaviation.com
Old 01-22-2021, 09:30 AM
Default OpLims requirement verified
Joe - thanks for the additional details. I have confirmed that my 2007-vintage Limitations include the requirement to report this to the FAA Registry.
It looks like I can ignore the online portal & do this the old-fashioned way. The recommendation to obtain proof of mailing is a good one. The postal service hasn't been doing that great a job around here lately.
Vic - yes, we did cover that this paperwork needed to be completed. It's just the mechanics of accomplishing this that has stymied me. You know I'm a computer guy, so I really wanted to make it work via the portal. :-) I'm sure I'm making this a lot harder than it needs to be.
Looking at the form, I'm okay with everything until I get to Section III.
- Item III.A - is self-explanatory
- Item III.B - do I need to enter anything here?
- Item III.C - there are two boxes for airframe hours.
- Do I need to fill in both?
- Do I use Hobbs or Tach?
It appears that I'm then done with no further entries after Section III.
Thanks!
David
2020 Dues Paid
Old 01-25-2021, 05:38 AM
Default Updating with info from FAA via Joe Norris
For future reference, here's what needs to be done:
Fill out a new 8130-6 and send it in the mail (yes, snail-mail) to the FAA registration branch with a note saying that this is a records update for a propeller change ONLY.
Sections I, II, and III should be completed. (The information on what to include on the form is my best guess, not confirmed by anyone else.)
Fill out all of section I, with the new prop info in boxes 9 & 10. Everything else in this section should match your current Airworthiness Certificate.
Section II only requires 3 checkmarks - "B" = Special AW Certificate, "4" = Experimental, "2" = Amateur Built.
Section III - subsection A should match existing registration. B does not need to be completed. In C fill in the current airframe hours. D is your certification including your signature.
Make copies of everything and send it by certified mail, registered mail, or another method that provides a record of its mailing and/or delivery. Keep the copies & verification of mailing with your aircraft records.
P.O. Box 25504
I'll update this post if/when I hear anything back from the registration branch.
David
2020 Dues Paid
Old 02-08-2021, 06:00 PM
Default The Saga Continues
Well, I sent the 8130-6 along with a cover letter explaining why I was sending it (change from fixed-pitch to constant-speed) via certified mail with signature confirmation. That cost about $6.
Today I received it back from Oklahoma City, with a cover letter stating:
"The enclosed FAA Form 8130-6 is being returned for your disposition. It must be submitted to this office by a Flight Standards District Office (FSDO)."
There seems to be some confusion over how to comply with this requirement that is in the operating limitations.
David
2020 Dues Paid
Old 02-08-2021, 08:31 PM
Ed_Wischmeyer's Avatar
Ed_Wischmeyer Ed_Wischmeyer is offline
I upgraded the RV-9A to constant speed prop and did it through the Atlanta FSDO. Took a while for the inspector to make it to Savannah, but he was great to talk to. And he checked the plane over pretty carefully -- but I'm always glad to have an extra set of eyes.
Don't recall any of the paperwork details, so can't help you there.
RV-9A at KSAV (Savannah, GA; dual G3X Touch with autopilot, GTN650, GTX330ES, GDL52 ADSB-In)
Previously RV-4, RV-8, RV-8A, AirCam, Cessna 175
ATP CFII PhD, so I have no excuses when I screw up
Too many safety posts purged without notice...
Old 02-08-2021, 09:09 PM
calpilot calpilot is offline
Requires "Amended" C of A per the operating limitations. Easy, send me an email to my private email, and I'll send you what you need!
DAR Gary calpilot123@gmail.com
