Old 12-20-2011, 07:57 PM
LifeofReiley's Avatar
LifeofReiley LifeofReiley is offline
Originally Posted by JohnJacobsen View Post
Nobody I know that has a D-180. Looking for a steam gage Airspeed to hook up for comparison.
Stop by the airport, we can locate one you can borrow for testing. I'll email my phone #.
Reiley
Retired N622DR - Serial #V7A1467
VAF# 671
Repeat Offender / Race 007
Friend of the RV-1
Old 12-20-2011, 08:57 PM
Tony Kirk's Avatar
Tony Kirk Tony Kirk is offline
Default Manometer Article
One of my fellow chapter members, John McAvoy, published an article in Sport Aviation about calibrating you airspeed system using a Manometer.
Here is the link to the article and materials on his webpage http://www.iflyez.com/manometer.shtml.
Yes, his favorite building material is different than ours, but I don't hold it against him.
Tony Kirk
Van's Aircraft Tech Support (working from home)
Building RV-7 (N777RV Assigned) First flight... Soon!
RV-6A N57TK, first flight 9/5/05...
Sold in 2011 after 725 hours of pure joy!
Old 12-21-2011, 09:42 AM
Vac Vac is offline
John,
Take a look at this thread: http://www.vansairforce.com/communit...=static+source .
What you're discribing might be a static source pressure error. There's some other good info on this phenomenon (provided by Kevin Horton) in the flight test section. You'll still need manometer data, but if that shows the Dynon display to be accurate, then you'll need some flight test data. It generally takes some effort to get indicated airspeed and altitude "dialed in."
If you have any questions, you can drop a PM or e-mail.
Vac
Mike Vaccaro
RV-4 2112
Niceville, Florida
Old 12-21-2011, 10:20 AM
jjconstant's Avatar
jjconstant jjconstant is offline
Is your static source in the same location and using the same pop rivet head as Van supplies? Both location and shape have a strong effect on indicated airspeed. Low indicated speed implies that you may be getting pressurized air in your static source. Deploying flaps can change your static pressures at the low end if you use differing static source locations and shapes.
All best
Jeremy
Old 12-21-2011, 10:30 AM
Bavafa Bavafa is offline
@ 35K, it seems like a big discrepancies
Is the airspeed off by a consistent amount or varies significantly?
You seem to have tested all but the instrument itself, so I would suggest to try to take that also out of the equation before messing more with the pitot/static system.
Of course, this is based on the assumption that the location of Pitot and static are on the suggested location by VANs. A quick check to make sure your pitot is not bent in a wrong angle, though doubtful since you have been checking every thing else.
Good luck
Mehrdad
N825SM RV7A - IO360M1B - SOLD
N825MS RV14A - IO390 - SOLD
N258SM RV14A - IO390EXP119 - In Paint shop now
Dues paid
Old 12-21-2011, 12:30 PM
I'm not exactly close by, but I have a new airspeed indicator sitting in the box at home. If you make it up to Dallas, you are welcome to borrow it for testing. Just e-mail me if you are interested.
Colin P.
RV-6A #20603
Complete 5/10/19
PP SEL / A&P
I donate every year on my B-Day (in Dec)
Old 12-21-2011, 05:34 PM
Walt's Avatar
Walt Walt is offline
If you get up this way to pick up the airspeed indicator in the above post, stop by and I'll throw my pitot static box on it and check it.
Walt Aronow, DFW, TX (52F)
EXP Aircraft Services LLC
RV7A built 2004, 2000+ hrs, New Titan IO-370, Bendix Mags, MTV-9 prop
Old 12-22-2011, 04:40 AM
JohnJacobsen's Avatar
JohnJacobsen JohnJacobsen is offline
The static is pretty close to Vans location. About half an inch forward. The air speed stays consistantly off thru the speed range.
Thanks for the offer to borrow an AS indicator in Dallas. I will see what I can get done down here first.
I have access to a pitot static test set down here.
Thank you everyone for all the suggestions and offers. Hope to have this figured out soon. This is a great community.
John Jacobsen
RV7 Flying "Aluminum Falcon"
Zenith CH750 (Scratch building) SOLD
Locost 7 (Lotus 7 replica)
Taylor TX
Youtube channel: http://www.youtube.com/user/johnjaco...e=results_main
Old 12-22-2011, 05:03 AM
NickAir's Avatar
NickAir NickAir is offline
Location: McMinnville, Oregon: HOME of the SPRUCE GOOSE
Let us know what you find out. Instrument or static system.
Tailwinds...
Simplicity is the ultimate sophistication.
Leonardo Da Vinci
Working on a RV-4
Citabria 7GCBC
Cessna 180, sold
RV7 I0-360 C/S, Slider, AP, Glass, etc. sold.
RV6 O-320 F/P, Slider, AP, Steam, etc., sold
Citabria 7KCAB rental
Piper Cherokee, sold
Sparrowhawk, sold
Proud -VAF- Supporter - Exempt, Dues Paid Anyway.
Old 12-22-2011, 08:00 AM
Brantel's Avatar
Brantel Brantel is offline
I went thru this as well.
http://www.vansairforce.com/communit...ad.php?t=56387
I think like post 64 is were I found the fix....
Brantel (Brian Chesteen),
RV-7/TU, #72823, N159SB
Track N159SB (KK4LIF)
