Old 06-07-2021, 12:35 PM
Freemasm Freemasm is offline
Default Aileron Skin
I'm building an F4 (Rocket lite) with a "standard" RV-4 wing. I've heard side discussions about the aileron skins being updated to a thicker gage. The skins I have are 016. I've seen an RV-8 drawing but it only references a pre-punched part/part number. No material dims.
What are my current risks as is?
Should I go ahead and plan on reskinning? If so, at what thickness?
One step forward. Two steps back. Story of my build life. Thx.
Old 06-07-2021, 01:07 PM
Looking at the RV-8 pre-punched Chapter 4, the parts list, the RV-8 aileron skins are .020.
Dave
Old 06-07-2021, 01:50 PM
HFS HFS is online now
Default Updating Aileron Skin Thickness
I think you will find Van's very reluctant to make "special" skins other than what is called out in the plans. 30 years ago they would (I have a set), but now - not so much. I tried to get them to make me a set of .020" aileron skins for an RV3 I am currently building - answer was "We don't do that anymore."
Good Luck - maybe an "aftermarket" manufacturer?
HFS
HR II S/N 002
Old 06-07-2021, 03:04 PM
Default Thanks to all
I suppose the 016s are guaranteed to crack?
Can probably form one myself if:
I can borrow the long brake at the FBO
I get enough 020 to ruin a couple first
Any other info, please forward along. Thx.
Old 06-07-2021, 07:45 PM
Stewbronco Stewbronco is offline
Default RV8 quick build ailerons
Just buy a set of RV8 quick build ailerons ....they come fully assembled and are same dimensions as RV4 ...
Old 06-07-2021, 09:46 PM
Nick's Avatar
Nick Nick is offline
This. Or -8 parts and build em up. I went from .016 RV-4 Ailerons to .020 skinned -8 Ailerons because of skin compression at higher speeds. Yes it's real and yes it made it fly like a new airplane.
Nick "Rehab" Nafsinger
91TS Rosharon, TX
RV-4 Bought 2019, Day to Day Restoration while still flying. SDS EFI IO-360, Hartzell CS, DanH inspired custom intake, G3x Panel
RV-8 SB, "Back burner project."
RV-10 Built 2010, Sold 2019
Old 06-08-2021, 07:23 AM
Default Dilemma
Thanks to all. Here is what I'm afraid of.
These are all slow build construction. If I purchase -8 parts (pre-punched), worry the ailerons will then be out of plane with the flaps. Or maybe the trailing edges won't align, etc.
I'd like to get a ride in this #$%@! thing before I die.
Old 06-08-2021, 12:33 PM
Default Not a worry
Ailerons and flaps will be fine as you would also need to buy some of the mounting brackets ( part number escapes me ) ...they come predrilled and blank ...so if the predrilled isn't bang on ....you can drill your own . Takes a bit of work and but covered in several posts on VAF
Old 06-08-2021, 01:46 PM
PhatRV PhatRV is offline
Even when you build the pre-punched RVs, there is no guarantee the flap and aileron edges are aligned perfectly.
RV8 standard build: 90% completed (90% to go)
Waiting to install wings to fuselage.
Days to Final Installation: 999
Days to AWC: 999
Days to First Flight: 999
Donation paid through 2022
