Old 04-11-2016, 08:36 AM
The Swede The Swede is offline
Default Emergency procedures
Haha, I can see the resemblance... But doubt bullets will come out of mine
Fredrik I guess it's just to keep keeping on with the Kitfox, finally it happens
Magnus I still have assembly, documentation and completion of hangar to do so I guess Falk?ping will be tight. Been following your progress and not envious with the proseal sessions, but it looks really good.
Not much done on the RV lately, waiting for painting of wings etc. But went to Uppsala/Sundbro, H?tuna and SK? for EAA emergency procedures program and tail dragger diff training. Time and money well spent, thanks to Patrik Sj?berg at avautbildning.se and I really enjoyed getting acquainted with the french wooden wonder Mudry CAP10C.
Carl
RV4 #2784
O-320 160hp, WW GA200L
982lb at 71,15"
SE-XZT
Gotland, Sweden
Old 04-12-2016, 11:58 AM
Default Wings are home
Wings, HS, flaps and ailerons at hangar. Time to do some assembly
Carl
RV4 #2784
982lb at 71,15"
SE-XZT
Gotland, Sweden
Old 04-15-2016, 02:26 PM
Default Baby steps
HS and pitot tube mounted:
And antennas
Waiting for painter to finish the VS and the rest of the rudders, maybe next week...
Carl
RV4 #2784
982lb at 71,15"
SE-XZT
Gotland, Sweden
Old 04-30-2016, 04:21 PM
Default Hangar finished and more...
Hangar floor rubber rolled in Swedish april weather:
It turned out pretty ok I think
Made some modest progress on the RV as well, rudder is now back at painter after marking of stripe position.
A/P servos and strobe on fin top connected, ELT installed.
Prop and spinner in place, blade angle 22 degrees. We'll see what static and performace it might give?!?
Carl
RV4 #2784
982lb at 71,15"
SE-XZT
Gotland, Sweden
Old 05-17-2016, 04:23 PM
Default Rudder is on...
Mostly electric work done recently, nearly finished with the DYNON installation. Just got rudder back from painter
Carl
RV4 #2784
982lb at 71,15"
SE-XZT
Gotland, Sweden
Old 05-18-2016, 05:25 AM
A2022 A2022 is offline
that's looking good! you live in the middle of the Baltic Sea. that will make a quick trip to the mainland. my daughter became a Swedish citizen several years ago. she lives in Malmo.
Old 05-18-2016, 02:02 PM
Default Good enough...
Thanks Steve, I used to live in the southern province myself. Nice part of the country
Tied the electrical and DYNON system up today to an hopefully acceptable standard. Please advice if you see something out of the ordinary.
Loose red/green wires are for tank level and will be sorted when wings are on.
Carl
RV4 #2784
982lb at 71,15"
SE-XZT
Gotland, Sweden
Old 05-18-2016, 03:07 PM
looks good! I am not an expert on the RV4 but I did see a possible edge contact here.
Old 05-19-2016, 11:51 AM
Default firewall passthrough
Thanks for the heads up Steve, firewall passthroughs will be filled with high temp RTV and then clamped on the engine side. This will straighten the cables/MAP-hose out a bit and the radious of the hole is quite smooth so I think it will be ok. I'll put up some pics from the engine side when finished with passthroughs, plan is to wait to see if everything is working as intended before filling the passthroughs.
Carl
RV4 #2784
982lb at 71,15"
SE-XZT
Gotland, Sweden
Old 05-19-2016, 12:08 PM
Default Major happening on the island of Gotland...
Wings are on, hopefully for the last time. Spars greased up they went in quite easily, next is to secure all of them spar bolts
Kind of unreal having done this building milestone, but it feels good
Now time for a building pause for the weekend, but will be some flying with the kids in the PA-22 that I recently cheched out on.
Carl
RV4 #2784
982lb at 71,15"
SE-XZT
Gotland, Sweden
