Source for 56 1/8" Metal Cutting Band Saw Blade
I've seen several queries on bandsaw blades through the years and would like to point out that if you go to your local welding gas and supply places (Holston Gasses here in Knoxville,Tn), they can make up any size blade you need. I give them the length, blade depth, and TPI and they usually crank them out in a couple of days. Something to consider when looking for blades as most manufacturers are geared towards woodworking blades rather than metal cutting. Why compromise and struggle finding sources when you can get exactly what you want.
