Go Back   VAF Forums > Model Specific > RV-14
  #11
Old 02-03-2021, 10:29 AM
mbell mbell is offline
Is the UV canopy an option from Vans, or something aftermarket?
Mike Bell
RV4-->6-->6A, (built by Villanueva, Tolle, and Mosher)
AirCam finished and flying!
RV-14A under construction.
Cameron Park, CA (O61)
Old 02-03-2021, 10:42 AM
Desert Rat Desert Rat is offline
I just did this last week for my RV7. It's from Vans. Little more spendy that the standard one, so hopefully it's worth it.
It's not listed as an option on the order form, you have to do it in the adds/deletes notes. The only way I knew about it was from reading threads here on VAF.
Edit- deleted the part numbers previously posted since they were for an Rv7 and this is a RV14 thread
Terry Shortt
AGI, CFI, CFII, MEI, A&P, Janitor
RV7 Empennage & Wing done
Fuselage in process
#72651
https://eaabuilderslog.org/?blprojec...t=all&listcat=
Old 02-03-2021, 04:52 PM
mc607 mc607 is offline
Does the UV canopy have a noticeably darker tint?
Are all canopies the same height or do they make one for taller folk?
Regards,
Todd
Old 02-03-2021, 06:59 PM
Mckay Mckay is offline
Following this as I want one as well.
Old 02-03-2021, 07:02 PM
Jetmart Jetmart is offline
Regards,
Todd
I do not believe that the UV canopy has a significant amount of tint if any at all.
They only make one size of canopy.
Glenn Martin
Windsor, Ontario
1942 Tiger Moth
2017 Waco YMF-5
Kit # 140694
Started October 22, 2019
Engine, prop, and cowling to complete
2021 Dues Paid
Old 02-03-2021, 07:33 PM
Thanks all
Old 02-03-2021, 08:19 PM
David Z David Z is offline
Does the UV canopy come for models other than the RV14?
RV-8
Empennage Passed Pre-close Inspection
Wings mostly done
Fuselage started
83126
Dash 8 day job is financing the RV-8
Donation till September 2021
Old 02-04-2021, 04:48 AM
Cwood2000's Avatar
Cwood2000 Cwood2000 is offline
I’m ready to order my fuselage and finishing kit.
1. Any advise on what items you would definitely swap out of the Vans kit for aftermarket?
2. Is the “fwf” included in the finishing kit?
3. What are the big ticket items that I can expect that are not included, to finish the plane. Not referring to 390, prop, avionics, paint or interior.
Contact AS Flightlines (TS Flightlines) if you want their FWF kit (highly recommended) and they will give you a list of part numbers for Van's to delete in their kit.
If you want to use a EarthX battery, different alternator, prop governor, spinner etc. Van's will allow you to delete from their kit.
Aka YellaDawg
RV14 First Flight 10.15.2019
RV14A under construction
2021 Dues Paid
Old 02-04-2021, 06:44 AM
RV6-KPTW RV6-KPTW is offline
I recollect that there were options for tinting but I elected the low UV canopy without tint.
Dennis Callaghan (X26)
- RV14 sn:140193 - first flight 12/19/2019
- 2000+ hours on my RV6! Sold (so sad...)
- donation 12/18/2020 * 2
Old 02-04-2021, 07:03 AM
Van's no longer offers the dark tinted canopy option on the 14. Only the standard and UV.
Glenn Martin
Windsor, Ontario
1942 Tiger Moth
2017 Waco YMF-5
Kit # 140694
2021 Dues Paid
