Andair extension part number?
Rick RV-4
Hi all,
This has been discussed before, but I'm still unclear as to what exactly I need for the fuel valve to make things fit right. I ordered the Andair valve from Vans, and know I need the extension piece, but do I only need the extension "tube", or the entire "extension kit"? One's about $30 and the other is about $150 from AS. I'm assuming it's only the tube (6" to be cut down a bit), but would rather order the right stuff the first time.
If it helps, I plan on combining this with Aerosport's standard center console and a 310 Carbon Fiber panel (but not the Quad Armrest - I'm going with simple vernier controls).
Part numbers (if you have them) would be even more helpful . . .
Thanks in advance . . .
Ricik
You need the kit, not just the tubing. The kit includes a new fascia and valve handle in addition to the extrusion (tubing).
Yes, the entire kit. You'll need to decide 6 inches or 12 and then wait a few months to receive it.
That's assuming everything is in line, if not you will need the universal joints. Pleasure never ends........
Here's the extension kit numbers I purchased for extending my FS20 valve. My new valve is at an angle so I needed the universal joint as well. I have a new Andair 6 inch extension if you need it.
Nick
N16KY
RV7 slider, center console, Titan IO370 9.6:1, Almost a 14er mod, SuperTracks mod, AFS panel
Just found the universal joint info:
Thanks Nick, for that part number. That helps!
I'd be willing to take that off your hands if the price is reasonable. Let me know via phone (612) two39-5one28
Or PM me and I'll reply to that as well.
Gracias,
Rick
