Keep VAF
Going
01-14-2021, 06:57 PM
Found some too
I installed two like this on my port inspection plate. Didn’t find them until last night. I tested the replacements and found two more in the bag prior to riveting them on. Glad I tested them first... the second time.
RV-14 Kit #140791
N791RX reserved
VS done
Rudder done
HS done
Aft fuselage in the works
01-15-2021, 08:15 AM
I was about to post the EXACT same thing today! I too found a couple nutplates without threads and of course, found them AFTER I finished riveting them in place. I was wondering how common this problem is. My -14A empennage kit was delivered in late Sept 2020. Perhaps Van's got a bad batch?
01-15-2021, 10:51 AM
Originally Posted by fixnflyguy
You can tap it, but it wont be locking then. I have tapped them and put fastener in with locktite. Be sure they are correct starting hole size for the tap. I'm pretty sure they are rolled threads from MFG, then "crushed" for the locking feature.
You can tap it with a Spirolock tap to have the self-locking feature.
01-15-2021, 02:09 PM
Chinese manufacture ???
Bruce W
RV-7 QB
(500+ hours)
Elk Grove, CA
01-15-2021, 07:15 PM
I've never found one that was not threaded. If I did, I would catch it during my install process because I use a short screw with a jam nut on it as kind of a holder, assures that it is centered in the (tight) clearance hole.
I position the plate nut with a cleco, then put the short screw in by hand until it gets tight at the locking squeeze. Then I spin the jam nut down on to the skin to keep the plate nut pulled up tight. Then the second attach hole is ready to rivet.
Aside from insuring that the plate nut lines up with the clearance hole, this process would immediately detect one that didn't get threaded.
Steve Smith
Aeronautical Engineer
RV-8 N825RV
IO-360 A1A
WW 200RV
"The Magic Carpet" Flying since Sept. 2009
Hobbs 635
LS6-15/18W sailplane SOLD
bought my old LS6-A back!!
VAF donation Dec 2020
01-16-2021, 12:51 AM
Used this method since I found out on my very first nutplate install that the threads don't necessarily align with the clearance hole if one of the rivets gets squozen more than few mrad off plumb.
Kurt Haller
P-town, CA (10 min from KLVK!)
N748PK, RV-9A
Flying as of 13 July 2019
VAF dues last paid 30 Dec 2020
01-16-2021, 01:27 AM
+2. Me too, Maybe this is a west coast thing?
01-16-2021, 05:04 AM
If they put threads in ALL of them, it takes the “sport” out of building.
Dennis W. Millsap
Retired Air Force
RV-6A built, flown and sold
RV-10 built, flown and sold
RV-12 built and currently flying
EAA Technical Counselor and Flight Advisor
A&P
01-16-2021, 05:28 AM
Nutplates without threads go back to the Wright Brothers (OK, slight exaggeration). Experienced builders check every nutplate before installing them. The problem will be eliminated when they get robots to make the nutplates.
You’re only as good as your last landing
Bob Barrow
RV7A
01-16-2021, 02:27 PM
Yes, true!
Also remember that in many places, the screws are supposed to carry shear through an assembly of parts, and it does this by bearing on the sides of the hole. If you open up the clearance hole so the screw goes in easily, then it is not transmitting shear properly, and you have only clamping friction left to do that -- not a good plan for shear strength.
Steve Smith
RV-8 N825RV
IO-360 A1A
WW 200RV
Hobbs 635
Thread Tools |
Search this Thread |
Display Modes |
Linear Mode
