  #21
Old 01-20-2021, 06:08 AM
PCHunt PCHunt is offline
Originally Posted by N661DJ View Post
I recently had my tip up canopy come open in flight, forgot to close the top latch.
On take off, full power, 800', 120KIAS. I thought I had been hit by a sidewinder missile, the canopy came open about 8".
I immediately grabbed the handle and tried to close it, it would only come down about 4" or so, pulling as hard as I could actually lifting myself out of the seat.
I realized that I needed to pull the power back but only had 2 hands and was reluctant to let go of the canopy handle, didn't know what that might of done, concerned that the canopy might come off and the results would not be good. After a second or two, I decided that my only option was to let go of the stick and pull the power. BAD decision, the airplane did an immediate, hard, nose down and left turn, by the time I had reduced the power and got my hand back on the stick I was at 400' looking straight at the ground. Not a good place to be. After getting the airplane under control, I was able to successfully land on the intersecting runway, mid field from 400' or so altitude.
I am 78 years old been flying for 40 year, several thousand hours of time, mostly in RV's, aside from an incident with ice in a Mooney, this is as close as I have ever come.
I have since sold the airplane and have related this story to the new owner in hopes that he will not make the same mistake. DOUBLE CHECK THE CANOPY LATCH. In closing, This is a fantastic airplane, the problem was with the pilot
not the airplane.
Fly safe,
Dick
I've had quite the opposite experience. When my RV-6A Tip-up canopy popped open, I just kept flying the plane. Never tried to close the canopy. The plane flew almost normally, with a slight, easily controlled nose down pitching moment. The canopy "floated" about 6-8" open. Trimmed it out, RTB, and flew a normal pattern, landed, and the canopy closed itself as I slowed in the rollout.
I suppose YMMV....
Pete Hunt, [San Diego] VAF #1069
RV-6, RV-6A, T-6G
ATP, CFII, A&P
2021 Donation+, Gladly Sent
Old 01-20-2021, 06:37 AM
sailvi767 sailvi767 is offline
I suppose YMMV....
My experience was exactly the same. The aircraft did have a easily correctable nose down pitching moment but otherwise flew normally.
G
RV-6 sold
F-1 Rocket
Old 01-21-2021, 12:36 PM
printbr printbr is offline
Originally Posted by JBPILOT View Post
Had a friend take off without latching tip up RV-12. Panicked, and turned and landed the best he could downwind. Totaled plane and bruised himself a bunch. Best not to try to close it. Slow down and land as soon as possible.
Was this friend in Minnesota around 2010? If so I have that RV12 now. It was rebuilt and flying. I did take off once without latching the canopy and immediately noticed before leaving the ground so pull the power and taxied off the runway and latched it. Now I check it religiously several times before departing.
Bruce Rawlins
Richland, WA
LSRM-A
RV-12 Flying
Old 01-21-2021, 12:54 PM
DaleB's Avatar
DaleB DaleB is offline
You and me both, brother. I was tempted to put a canopy latch switch in line with the spar pins, but that would make it a pain to taxi with e canopy unlatched. So, I was working on a little adapter to add a canopy switch, active only when RPM exceeds a set threshold, but didn't finish testing it. Figured just getting better about following the pre-takeoff checklist religiously was probably a better option.
Dale
Omaha, NE
Previous RV-7 project (sold)
Old 01-21-2021, 12:58 PM
Piper J3's Avatar
Piper J3 Piper J3 is online now
Now there's a thought...
Jim Stricker
EAA #499867
Bought Flying RV-12 #120058 Oct 2015 with 48TT - Hobbs now 633
Old 01-21-2021, 01:30 PM
HansLab HansLab is offline
Default switch
I just put a microswitch behind the canopy handle, quite sharp so, that a red light lits on the panel when the canopy isn' t fully closed. That way I can taxi with the canopy partly open, the red light blinking (and the checklist) will help me remember.
Hans Labruyere
build & sold project Kitfox IV
Project bought & flying RV12 #120742
Donation 2021 paid
