-6 slider top baggage bulkhead vs canopy track
rv7charlie
Starting the 1st annual on the new-to-me -6, & discovered that the all-thread brace for the center canopy track goes through (as in, a hole; not a notch) in the baggage bulkhead top panel. I'm told that the -7/-9 sliders notch this panel so it can be removed without disturbing the track brace. Should the -6 be notched, as well? Since the fuselages are so similar, I'm wondering if the builder just 'missed a memo' on notching this panel. Not much detail in the -6 preview plans. (Yes, I'll be ordering the USB drive.)
Charlie
Slip a piece of black heat shrink tubing over the threaded rod, gives it a more finished look.
