w/a Donation
VAF on Twitter:
@VansAirForceNet
Old 05-19-2023, 11:58 AM
Desert Rat Desert Rat is offline
Default how to shoot this rivet?
How the heck did you guys shoot this rivet? I must have 15 bucking bars including a couple made from tungsten helicopter mast weights that aren't much bigger than my thumb, and I cant figure out how to get any sort of bar on the back side of this thing. I can barely get my finger on it without a bar?
It's common to the skin overlap, longeron, and the strap that ties into the F-704 Vertical member, so I suspect it's kind of an important little fella. I'm going to call vans this afternoon and see if they approve a pull rivet here unless somebody offers up a better solution before then.
Terry Shortt
AGI, CFI, CFII, MEI, A&P, Janitor
RV7 Empennage & Wing done
Fuselage almost done
Avionics almost done
90% done, 90% to go
#72651
https://eaabuilderslog.org/?blprojec...t=all&listcat=
Old 05-19-2023, 12:15 PM
Stoo Stoo is offline
Put a Cherrymax rivet in there. I had to use several in that area on my 6 due to access problems.
Stewart Willoughby, 6
Old 05-19-2023, 12:23 PM
scrollF4's Avatar
scrollF4 scrollF4 is offline
Moderator, Asst. Line Boy
What Stew said. You can fill the center hole with epoxy so it looks fine under paint, then build on!
The Mothership can offer specific cherrymax options, of course.
Scroll
VAF Moderator
FFI Check Pilot
Exemption waived.
Proud and grateful 2023 -=VAF=- Contributor
Old 05-19-2023, 01:19 PM
doug_rv7 doug_rv7 is offline
Default Back rivet strike plate?
Will the strike plate to your back rivet set fit in there? I used that in some tight fitting places. It took a couple extra bursts with the rivet gun but it worked fine.
Doug
RV-7
Flying!!!
Old 05-19-2023, 01:22 PM
bjdecker's Avatar
bjdecker bjdecker is offline
For this rivet, and the rest of them along the side rails, I used a squeezer yoke for the bucking bar.
Brian Decker
EAA Technical Counselor
RV-7 (Flying)
Old 05-19-2023, 04:17 PM
wirejock's Avatar
wirejock wirejock is online now
Default Home brew bar
No CherryMax in 3/32. You might ask Vans about going up to #4 and using a CherryMax.
I have a variety of home brew bars. I have a thin tungsten that fits almost everywhere. I often taped the heavy tungsten to it for extra mass.
The tight spots were done with a piece of steel thin enough to fit. Even a flat blade screwdriver will work. The heavy tungsten was taped to the steel bar as close to the impact point as possible. It adds the mass. Same problem with rivets near the roll bar if you have a slider.
Larry Larson
Estes Park, CO
E-mail: wirejock at yahoo dot com
Builder Blog: http://wirejockrv7a.blogspot.com
Donated 12/2022, plus a little extra.
RV-7A #73391, N511RV reserved
Disclaimer
Old 05-19-2023, 05:51 PM
Taltruda Taltruda is online now
I think this would work.. while not a Cherry Max, its a Cherry..
https://www.aircraftspruce.com/catal...erryRivets.php
Tom
Las Vegas
RV-4 flying…
RV-8 empenage finished 10-2020
Wings Started.. 11-2020
Old 05-19-2023, 06:31 PM
wirejock's Avatar
Default Cherry
Not structural. I have some. They are marginal for holding nutplates. Best ask Vans if it's approved.
A MK-319-BS would be stronger but the grip length probably isn't long enough.
Larry Larson
Estes Park, CO
Disclaimer
Old 05-19-2023, 08:14 PM
Tommy123 Tommy123 is offline
There are no structural 3/32 Cherry Max rivets. 3/32 Cherry is NOT a Max and NOT structural.
Old 05-19-2023, 08:23 PM
wirejock's Avatar
Default CherryMax
Isn't that what I said?
Larry Larson
Estes Park, CO
Disclaimer
