Jim, a good spot that's often used and away from ferrite interference is on a tray, suspended from the upper framework, just behind the baggage area.
It's also easily accessible by simply removing just the upper half of the baggage wall.
Best,
I would recommend greatly simplifying the pitot/static connections and hookups. There are extra joints in that particular setup as shown for leaks to eventually develop. Not flaming the install, just saying it could be simper from a plumbing perspecting - and simpler is almost always better when it comes to pitot/static plumbing.
The shelf depicted above is very common as is the aft deck, but I would recommend greatly simplifying the pitot/static connections and hookups. There are extra joints in that particular setup as shown for leaks to eventually develop. Not flaming the install, just saying it could be simper from a plumbing perspecting - and simpler is almost always better when it comes to pitot/static plumbing.
And yes, the other folks are right...one antenna for each comm radio.
Stein
I guess I don't get it. How are there extra joints in that setup? He has one tee in each line. How can you reduce it any further?
Look carefully...there is at least 2 extra tube joints and a section of tube that don't need to be there, then the routing of the lines (straights where 90's would be better), etc.. Overall could be a lot cleaner. Not flaming anyone because he used what he had and reports that it obviously is working, but if you're starting from scratch you could clean it up quite a bit (also using far superior and much less bulky fittings). In reality, the truth is that the pictured install is still pretty good compared to a lot of older certified airplanes (ask Walt, we both can tell you some horror stories)!
Stein
I see the extension now, thanks. It's easy to miss in the picture. And I agree with respect to the 90 degree fitting comment and the bend radius.
You say other fittings are superior? I redid my plane with them and the avionics guy who inspected and did the paperwork said he didn't like them as they were leak prone. I believe he liked the brass ferrel versions, but not 100% sure.
