Looking on the Garmin Website for the 430, the specs list voltage as 14-28 volts for Part Number: 010-00139-11 430 radio. A lot of the newer radio designs accept a large voltage range so that the manufacture only needs one part number for all aircraft.
I hope this helps. If something is found different please post it here.
That must have been the worlds hardest landing to knock off the data tag or something fishy is going on. Those tags are usually put on securely. I would be proceed with caution.
