My RV-10 tires wear quickly on the outer edges, leaving a scalloped tire. When you look at it from the front, the wheel has a lot of camber. My RV-6A wears on the edge also, but not near as bad. I wonder if it was designed to be correct when at gross weight - I normally don't fly at gross, but with 2 people/light load. I've thought about bending the gear leg axle up a few degrees (perhaps get Harmon Lange to do it), but I'm not sure how well that would work. Does anyone else have an issue with tires wearing off the edge?
Kevin Belue
Kevin Belue
