Old 05-19-2022, 01:43 PM
togaflyer togaflyer is offline
Default Need a harness recommendation
I will be installing a Surefly e mag in my RV10 with an IO540. I currently have Bendix mags so I need to replace the one harness to accommodate the Surefly. Any good sources where I can order a single harness and is there a specific harness I need to order (Other than just a generic 6 cylinder Slick harness), i.e. a specific Parts number I need? Thanks….
Rich Gurr
RV 10 924RL
9A0 & FD51
Old 05-21-2022, 02:13 AM
deek deek is offline
Check out the Maggie harness.
https://www.newhorizonsmaggieaircraf...efly-harnesses
https://www.newhorizonsmaggieaircraf...aggie-ignition
'83 LongEZ - N888EZ 3,371 hours (sold)
'89 LimoEZ - N26EZ 686 hours (sold)
'71 V35B
Next: Rans S-21 or RV-15 - need something to build
Old 05-21-2022, 05:03 AM
RV6_flyer's Avatar
I am planning on using a G3i Ignition harness with my SureFly ignition system.
Gary A. Sobek
NC25 RV-6
Flying
3,500+ hours
Where is N157GS
Building RV-8 S/N: 80012
Old 05-23-2022, 07:32 AM
So here is a question auto plugs vs aviation. I’m running Tempest fine wire plugs. Since I need a new harness I have also looked at getting an auto plug harness for the Surefly by G3i. I’m running an io540 in my RV 10. I have been told that the auto plugs are not durable compared to aviation plugs, which are beefy. Also an auto plug set up does not do well at higher altitudes i.e. 10k-14k. I’m on the fence if I should stay with the fine wires or switch to auto. And thanks for the info on Maggie harness.
Rich Gurr
RV 10 924RL
9A0 & FD51
Old 05-23-2022, 07:49 AM
rocketbob's Avatar
Suggest Denso 5003 M22 plugs and G3i harness. Make sure you use red loctite on the end threads and not get any loctite on the shoulder for good contact. I just ordered a replacement fine wire plug for a customer who dropped one which cracked the resistor. $160 for one fine wire plug with tax and shipping. Crazy!
Bob Japundza CFII A&PIA
N678X F1 Rocket, under const.
N8155F C150 flying
Not a thing I own is stock.
Old 05-23-2022, 02:58 PM
Got an e mail in to G3i, there is no phone number. Is there anywhere else to go for a slick cap with an auto plug set up ?
Rich Gurr
RV 10 924RL
9A0 & FD51
