Go Back   VAF Forums > Model Specific > RV-4
  #11
Old 08-08-2022, 09:09 PM
TomRV8 TomRV8 is offline
Default Same here
Mine has done the same thing, and Iím positive that area is built per plan.
I am certain itís because thatís where I put my weight to lift myself out (180 lbs) I have since started sliding up the seat slightly so I can grab the lower part of the roll bar to extricate myself.
Tom Chapman
San Antonio, Ft Worth
Flying my recently completed -10
Building RV-7A
Flying RV-4 since 1988
Flying Rans S-7S Courier since 2010
Old 08-09-2022, 01:11 AM
RVSpike RVSpike is offline
I also had the same issue years ago. I stop drilled the cracks and installed a couple of .063 doublers to spread out the load.
Click image for larger version
ID:	29250  Click image for larger version
'95 RV-4 SN3389 w/1650 hrs
O-360 A1A Hartzell C/S
Lightspeed Plasma II - E-Mag
Old 08-09-2022, 10:22 AM
Roadjunkie1's Avatar
Roadjunkie1 Roadjunkie1 is offline
Default Not quite right.....
OK: I guess that lifting yourself from the cockpit by the side rails is a common method of entering and exiting the airplane. And it looks like cracks have occurred there before. The last post looks like a decent fix to that problem. Personally, I use the rollover structure to slip in and out of the cockpit.
However, looking at the second image I am concerned with several things:
1) There is no underlying angle seen under the cockpit rail as seen on the other side and as plans call for. Thus, the bolt holding the rollover structure is not within edge-distance requirements of proper construction.
2) There is a hole peeking out from under the foot of the roll over structure indicating that a hole was previously drilled in the underlying angle (that I assume is there) and the hole for the current bolt is very close to that hole and, if it goes through the underlying angle, once again, does not comply with edge-distance requirements of construction.
IMHO. The mechanic in me sees things that don't look quite right, like this. If you are happy with how this is, I guess I should be as well. I apologize for being so picky.......
Michael
RV-4 2860 SuzieQ
1946 C-90-8 J-3 Cub
The adventure begins when things stop going as planned - Glen Heggstad
Exempt but still a happy Subscriber!
Old 08-09-2022, 10:54 AM
MS1095 MS1095 is offline
I agree it looks like the angle is missing. Can you post a few other pictures from the side and underneath looking up?
Old 08-09-2022, 07:54 PM
riobison riobison is offline
Default Repair
I can remember when I was 180 pounds, everything was easier
I like RVspikes fix. it's similar to what I was thinking. I'm glad I'm not the first that this has happened to.
Yes, all of the 1" angle is there as well as all of the supports and rivets.
Thanks for the help everyone.
Tim
