Go Back   VAF Forums > Model Specific > RV-4
  #11
Old 12-21-2021, 02:53 AM
emsvitil's Avatar
emsvitil emsvitil is offline
Are the flaps and ailerons reflexed a little (with tip matching) to get the fastest speed?
Ed
Old 12-21-2021, 09:09 AM
Little Al Little Al is offline
Curious has anyone tried these on a Rocket that already has shorter wings. At what point having to little wing aspect ratio starts to hurt performance? Also wondering the gain compared to a good sharp sheared wingtip. It just says 3mph gain over a flat cut off tip.
Old 12-21-2021, 10:14 AM
Laird's Avatar
Laird Laird is offline
Default Reflexing flaps
If I've got my facts straight (not guaranteed) the NACA 23012 airfoil that the RV-3/4/6/7/8 uses has less of a pitching moment than the Roncz airfoil of the RV-9/10/14 so reflexing the flaps (or ailerons) doesn't have the same effect.
You'll notice that the Roncz airfoil airplanes have a larger horizontal stab to balance the higher pitching moment. Reflexing the flaps reduces the pitching moment of the wing and unloads (reduces the (-) lift of) the stab in cruise which causes the increase in speed.
That's my story and I'm sticking to it....
Laird
Old 12-21-2021, 10:39 AM
Mike S's Avatar
Mike S Mike S is offline
Senior Curmudgeon
Bob Mills did at the Reno Air Races this year.
He, Steve or Bob K. should be the ones to comment as to the speed change.
Mike Starkey
VAF 909
Rv-10, N210LM.
Flying as of 12/4/2010
Phase 1 done, 2/4/2011
Old 12-21-2021, 10:47 AM
Bob Kuykendall's Avatar
Bob Kuykendall Bob Kuykendall is offline
Originally Posted by Laird View Post
...the Roncz airfoil of the RV-9/10/14...
The RV-9 does indeed have a Roncz airfoil. But the RV-10 and RV-14 have an airfoil that Steve Smith (scsmith) designed especially for Vans.
Bob Mills writes a bit about that in this earlier VAF thread.
Bob Kuykendall
Low-drag wingtips for RV-4 through RV-8
EAA Technical Counselor
Old 12-21-2021, 11:22 AM
PhatRV PhatRV is offline
Originally Posted by scsmith View Post
We periodically post updates on the tapered composite wing project in a separate thread, but we are probably overdue. We have closed the wings, and chased all but one fuel tank leak. Should have that one fixed next weekend. Bob Mills has match-drilled the aluminum stub spars to fit his Rocket-6.
Next up will be a static load test, end of January. In the mean time, I am starting to work on the ailerons and flaps.
I can't wait for the next update.
RV8 (N38PV): 90% completed (90% to go)
Short List for Hangar !
Days to Final Installation: 999
Days to AWC: 999
Days to First Flight: 999
Painting: 85% completed
Donation paid through 2022
Old 12-21-2021, 11:25 AM
scsmith scsmith is offline
Ah-hem.....yes John Roncz did design the RV-9 airfoil. But as Bob K mentioned the RV10/14 airfoil is mine. Reducing pitching moment is a benefit, as you describe, except that all these airfoils have very low section pitching moment. The large tail was added to the -9 because of the large slotted flaps which do add quite a lot of pitching moment.
Reflex (negative flap) primarily helps by keeping the nose of the airfoil at the best angle to promote laminar flow. Both the -9 airfoil and the -10/14 airfoil do maintain a modest amount of laminar flow. The NACA 23013.5 on the earlier designs does not. If you have a -9 or -10/14, keep the bugs cleaned off the wing and don’t paint trim stripes on the leading edge.
Laird
Steve Smith
Aeronautical Engineer
RV-8 N825RV
IO-360 A1A
WW 200RV
"The Magic Carpet" Flying since Sept. 2009
Hobbs 700
also
1/4 share in 1959 C-182B (tow plane)
LS6-15/18W sailplane SOLD
bought my old LS6-A back!!
VAF donation Dec 2021
Old 12-21-2021, 03:16 PM
Laird's Avatar
Reflex (negative flap) primarily helps by keeping the nose of the airfoil at the best angle to promote laminar flow. Both the -9 airfoil and the -10/14 airfoil do maintain a modest amount of laminar flow. The NACA 23013.5 on the earlier designs does not. If you have a -9 or -10/14, keep the bugs cleaned off the wing and donít paint trim stripes on the leading edge.
Thanks for clearing up my mis-information Steve. I stand corrected and more informed!
Laird
PS. Wingtips look Awesome. Hope you sell a ton.
Old 12-21-2021, 04:27 PM
bjdecker's Avatar
bjdecker bjdecker is offline
Default My .02
For grins/giggles -- https://www.nasa.gov/sites/default/f..._wing_k-12.pdf
Kinda looks like Steve...or his dad (or Richard Whitcomb)
Seriously impressive work sir.
I was hoping to get these tips installed before years end - but the Tax Man and Santa Claus conspired against my bank account. Next year....Next year....
Brian Decker
RV-7 (Flying)
Old 07-23-2022, 04:39 PM
Default Comparison test data
Steve Smith and Bob Mills have been very busy at the HP workshop getting the tapered carbon fiber wings onto Bob's Rocket Six in time to turn laps at the NCAR Reno Air Races.
But we've finally made time to do some comparison testing between the HP racing wingtips and the stock W715-1 wingtips. We did Kevin Horten 3-leg GPS triangles at four different altitudes (6000, 7500, 9500, 11500 MSL), first with the HP tips, then with the factory tips two hours later.
As expected, we found a solid 3-knot improvement at 6000 feet, and the data graph points to more at lower altitudes. The crossover altitude appears to be right around 11,000 MSL.
We also tested the stall speed, and found that it was only about 2 knots IAS faster with the short tips.
Bob Kuykendall
