Go Back   VAF Forums > Model Specific > RV-4
Old 06-03-2021, 03:06 PM
FinnFlyer FinnFlyer is offline
Default Non-wood anti-shimmy gear leg fairings?
Is it crazy to consider this idea:
Discard the stock fairings (don't use if not installed yet).
Shape relatively high-density foam in the shape of the gear leg fairings.
Make tunnel for brake line.
Cut out 1 to 2" long spaces for and add front and rear wood blocks front and back in upper, center and bottom positions (shaped as the cut-outs from the foam).
Wrap with fiberglass and resin.
Smooth to final finish.
Too much work?
Will never work?
Obviously proper alignment is critical as no adjustment possible once the foam, wood blocks and fiberglass are bonded with resin. Although one could wax the legs, but then how would the assembly be securely held in place?
I assume that foam would easily be crushed by the back-and-forth shimmy, thus the 6 wood blocks for each leg.
Finn
N214FL RV-4 Mazda 13B Renesis First flight 20 Feb 2021
N46AZ RV-3B Mazda 13B EFI -- Bought -- Flying
N993FL RV-3A Mazda 13B NA 575 hours
Old 06-03-2021, 04:36 PM
It's a whole lot easier and probably more durable and effective to make thick aluminum strips that fit inside the fairings, and attach them to the gear legs with Adel clamps. An RV-6 owner locally did this and it worked perfectly.
I think he used 7 Adel clamps per strip.
And no, I can't say what the optimum size of aluminum is for this. His pieces were fairly thick but I suspect (no data) that thinner would work fine.
I plan to use 1/8" x 1.5" aluminum strips on my RV-3B when it's far enough along.
Dave
Old 06-03-2021, 05:57 PM
PaulvS's Avatar
PaulvS PaulvS is offline
I too think that the aluminum strips with Adel clamps is the way to go. This method will allow the gear leg to move up and down as it should, but not fore and aft as it shouldn't. There's also little risk of trapping moisture, which has caused corrosion on some gear legs that have been chemically bonded.
Paul vS (yes I'm also a Van)
Building RV-6A #22320 O-320 FP. Wings and tail complete, fuselage almost done, working on canopy.
Flying my Aeroprakt A-22 STOL and the aero club's RV-9A while I build
Old 06-03-2021, 07:31 PM
mtnflyr mtnflyr is offline
Default Aluminum stiffeners
David Paule recommended I use aluminum for my stiffeners after a discussion on how to resolve severe main gear shimmy. Hopefully, you can see these images. The stiffeners are stout and you could probably get away with thinner aluminum, but they solved my problem nicely. Our airfield has some taxiways in pretty tough shape and my main gear are rock solid now. The difference is night and day. Before installing the stiffeners, I thought I was going to break something when I got going faster than a plodding walk on these taxiways. Now, I don't have to watch my speed at all. It's almost fun to taxi.
I used spacers cut on my lathe and alternated the Adel clamps to keep the stiffeners normal to and aligned with the gear leg centerline. I used decreasing-sized Adel clamps as I moved from the top of the gear leg to the bottom and calculated the spacing to place each clamp over the part of the gear leg that corresponded to the design diameter for that Adel clamp.
Getting the stiffener perfectly aligned took some noodling. I ended up chucking a 12-inch section of pipe in my lathe and bored it to a slip fit on the upper bosses of the gear leg. Drilled and tapped for a socket head cap screw in the pipe to lock the rotation when I had the leg where I wanted it. Clamped the pipe in my welding table vise and installed the stiffener with the clamps just snug enough that I could still move it around. Installed the fairings and got the stiffener right where I wanted it. Removed the fairings and tightened the adel clamps. Solid. Be careful drilling the holes in the stiffener. You need to get them the right distance off the adel clamp to keep it vertical without any wobbling. I did some test fitting with aluminum scraps to get the distance right so that I compressed the rubber on the adel clamp. Ended up very solid.
https://www.dropbox.com/s/1dlhrdyhqk...ner1.png?raw=1
https://www.dropbox.com/s/5ovru70pfg...ner2.png?raw=1
https://www.dropbox.com/s/8f75le2wpm...ner3.png?raw=1
Old 06-04-2021, 04:36 AM
fixnflyguy fixnflyguy is offline
Default My thoughts..
Lots of ways to skin the cat here, however I would not consider the bonded one piece fairing damper a great idea. The legs do a whole lot of moving within the hollow glass wrap leg fairing, and virtually every component of the "system" has relative movement. The leg fairings must be wear tolerant in the cuff fairings, the pant intersections and the length of contact with the steel gear. The dampers (wood/metal/fiberglass) simply null the resonance of the steel leg shake frequency and are not intended to make the legs "stiffer". I used the typical wood stiffeners and bonded them to well painted steel legs with Proseal, then wrapped with a couple layers of glass. Be CERTAIN the steel legs are protected from any water entrapment/bare metal areas..these badboys will rust in short order and crack because of it. The fiberglass fairings "float" as designed over the leg/stiffener and I sanded/filled/painted the inner surface with teflon infused urethane, as well as the upper and lower cuff/paint intersection fairings so there is zero chafe spots. the raw finish on the inner surface of the glass fairings will quickly act like a rasp file on your gear legs if not smoothed and sealed. In hind sight, I may have eliminated the stiffeners all together, as many have been fine without..all depends on runway surface, alignment and wheel balance.
Bill E.
RV-4/N76WE
8A7 / Advance NC
Old 06-04-2021, 07:04 AM
Default Heavy?
Thanks. That looks like pretty thick (3/16? 1/4"?) alum bars. With the Adel clamps how much weight did it add?
Finn
Old 06-04-2021, 07:15 AM
Seems there are different opinions here as to what the "stiffeners" do.
One is to make the fore-aft gear leg wider and thus stiffer, like an RV-8 leaf gear. The other is to make wood act as a dampener. However, does seem that wood wrapped with fiberglass also widens and thus stiffens the fore-aft motion.
I suspect that 1/8" thick alum bar will buckle under the fore-aft forces. I do understand the appeal of this method: removable, making it possible to adjust and to inspect for corrosion. Drawback got to be the added weight.
Perhaps the wood/fiberglass method is also somewhat gentler on the engine mount where the gear leg sockets are attached?
Finn
Old 06-04-2021, 07:48 AM
My working hypothesis was that we needed to separate the fore-aft section moment of inertia from the vertical.
I do not think that dampening is the goal. Dampening requires motion to work since dampening is a function of relative velocity and we didn't want motion in the first place.
Dave
Old 06-04-2021, 07:50 AM
HFS HFS is offline
Default FYI - Van's Original Instructions
Page 10-5 of Van's original builder's manual, (mine from 1985) instructs ... The gear leg/dampening block assembly can be covered by an aluminum fairing as shown in SK-64, or can become part of a foam/fiberglass as shown in SK-66 (See attached photo of SK-66). ...
So you can see, at least in the original design, that the streamlined foam/wood wrapped in fiberglass was an "approved" method for a gear leg fairing. This doesn't mean that this method is without its faults, but merely to illustrate Van's thinking early on.
As an aside, I used this method; and, until a subsequent owner put the airplane up on its nose, wrinkling the firewall and bending the gear legs - hence requiring replacement, this method worked just fine.
Click image for larger version
Name:	Vanís SK-66.jpg
Old 06-04-2021, 09:44 AM
Thanks David. So that's where I got the idea! Just now I dug out my old RV-3 manual. SK-63 through SK-69 outline the different methods back then. Interesting that the wood strips are held to the gear leg by 2 to 3 layers of 9 oz fiberglass cloth tape before the trailing edge foam and final layers of cloth is added. That would indicate that the foam would be crushed if used alone.
My RV-4 project actually came with the two-piece alum fairings. So I guess I'll use those.
Finn
