Old 03-03-2021, 06:29 PM
WingnutWick's Avatar
WingnutWick WingnutWick is offline
Default Starter issues - not fully engaging.
Hi all, had some starter issues on the 6A today. Upon initial pushing of the starter button the starter engages then if it doesn’t catch right away it seems as if the gear starts disengaging while still spinning. This is evident by a horrible grinding sound and the engine not spinning. If held a little longer the gear disengages completely and I can hear it spinning but completely disengaged. Subsequent start attempts result in the same thing.
Any ideas what failure mode this is before I start going down rabbit holes?
Thanks!
-Wingnut
F-18E/F, Mk.58, CF-5
RV-8 O-360
Old 03-03-2021, 06:33 PM
Mike S's Avatar
Mike S Mike S is offline
Senior Curmudgeon
Sounds like the Bendix unit needs cleaning and fresh lube.
There has been discussion on this in the past, it might help to tell us what starter you have.
https://vansairforce.net/community/s...starter+bendix
https://vansairforce.net/community/s...d.php?t=135453
Mike Starkey
VAF 909
Rv-10, N210LM.
Flying as of 12/4/2010
Phase 1 done, 2/4/2011
Old 03-04-2021, 11:53 AM
lr172 lr172 is offline
Two styles of starter. In one, the solenoid pull the gear into engagement. In the other, rotaational inertia drive the gear into position. Hard to help when we don't know what starter you have.
Larry
