Old 06-11-2008, 06:00 AM
Harold Lanfear Harold Lanfear is offline
Default Grove gear bolts bottomed out
We just did the final assembly of my Grove airfoil gear and noticed that the NAS 6206-36 bolts (supplied by Grove) would turn in the holes after full torque was complete. When I measured the thread from the washer head under the nut to the end of the bolt, it was clear the bolts were a few thousandths too long. We'll have to add another washer.
By the way, these are the two outboard, hardened bolts on each gear - the ones that are hard to get at I've sent a note to Grove, but haven't heard back yet.
If you are installing or retorqueing (have no idea how to spell that) your bolts you may want to confirm the nuts have not bottomed. I'll update after I hear from Grove. I did confirm the thread and bolt length versus specs.
Harold
Kitfox sold 2010; RV-8 85% and moving at the speed of a used Edsel
Old 08-24-2009, 09:06 PM
BuckWynd's Avatar
BuckWynd BuckWynd is offline
I've had the opposite problem. After installing the Grove-supplied NAS 6206-36 bolts, it's become apparent that the bolts are about one step too short. I don't have the required minimum 1-1/2 bolt threads showing. Will be ordering longer bolts shortly, I guess -- but only after a call to Grove and/or Vans first.
Anyone else had this happen?
Buck Wyndham
Northern Illinois
RV-8 N18XL
Old 08-24-2009, 09:19 PM
Doug Knab Doug Knab is offline
Default Grove Gear Leg Bolts
I've had the same problem with the non airfoil Grove gear legs. I added an extra washer and the bolts torqued up fine.
DanH's Avatar
DanH DanH is offline
Hmmm....mine were the correct length when used with the supplied nuts, but too short for the taller, stronger nuts. I too need longer bolts.
Dan Horton
RV-8 SS
Barrett IO-390
Old 08-27-2009, 03:27 PM
scsmith scsmith is offline
Default Remember NAS gear bolts sized by grip length
Hey guys,
remember that NAS bolts are sized by grip length, not overall length.
The stock gear bolts are NAS6206-27. For those of you that would like to use higher strength nuts and find that your stock bolts are not long enough, GAHco has NAS6206-28 that should be enough longer. For anyone that finds that the nut bottoms out, They also have NAS6206-26.
For the folks with Grove gear, the gear leg is thicker, so the bolts are longer, but I do not believe they are NAS6206-36 - that would be 9/16" longer than stock! The grove gear are not that much thicker, are they? So, remember when determining what length you need that the size number is the grip length.
GAHco has lengths of 26,28,30,31,32,34,35,36 listed on the website.
This may seem a bit of a tangent, but for people wrestling with bolt length to fit with the taller nuts, here is a thought:
This may be controversial and is intended as much as a question as a statement: Normal practice for nylon lock nuts (AN365) is to have 1-1/2 threads extending beyond the nut, right? I can see that this is important for two reasons. One- if you can see the end of the bolt, it assures that it went all the way through, and Two - since the nylon locking feature is just at the very end, you would not get full locking effect if only the last thread ( which is a little undersized from the end bevel) was in the nylon. BUT with a metal locknut that is made by deforming the last several threads of the nut, it would seem accepable from a functional standpoint to have the end of the bolt just barely beyond the nut. You will get full locking effect because several threads are deformed, and you will get full strength as long as the bolt is all the way through the nut. Finally, the NAS bolts come with a fairly short threaded portion. This leaves very little lattitude in adjusting nut position on the bolt - there is very little length change between bottoming on the thread and having the end of the bolt not extend beyond the nut.
Thoughts?
Steve Smith
Aeronautical Engineer
RV-8 N825RV
IO-360 A1A
WW 200RV
"The Magic Carpet" Flying since Sept. 2009
Hobbs 635
LS6-15/18W sailplane SOLD
bought my old LS6-A back!!
VAF donation Dec 2020
Old 08-27-2009, 05:29 PM
Toobuilder's Avatar
Due to weight concerns, the military aircraft program that I work on deviated from the "1 1/2 thread protrusion" standard 50+ years ago and allows "flush" ...but we don't use nylock nuts either.
Michael Robinson
______________
Harmon Rocket II -SDS EFI
RV-8 - SDS CPI
1940 Taylorcraft BL-65
1984 L39C
Old 08-27-2009, 07:07 PM
BuckWynd's Avatar
After checking this evening, I can confirm that for the airfoiled Grove gear on an RV-8, the Grove-supplied bolts are NAS6206-36s, with a length of 2.704". The Grove gear legs themselves are not that much thicker than the stock gear, but the Grove saddles definitely are. They stick out significantly past the edge of the fuselage.
If you use the taller NAS1804-6 nuts (as discussed elsewhere in this forum), you will not have 1-1/2 threads showing when you're done torquing them. Whether this would be an issue with your DAR is unknown. I just know that I don't want to chance it. And I certainly don't want to re-do anything inside those bleeping gear towers any more than I have to.
I propose that an NAS6606-36 bolt would be suitable in this application, since it's 2.828" long (about 1/8" longer than the Grove-supplied bolt), but with the same grip length. As Steve pointed out, NAS bolts are sized by grip length, not overall length, so the "dash" number would be the same. The 66XX series has longer thread lengths, or "T" lengths.
I have not yet fully explored what installation consequences there might be with a longer bolt -- it doesn't look like there will be any in my airplane, but your situation might be different. And remember, I'm referring to:
1. An RV-8,
2. The airfoiled Grove gear,
3. The taller NAS1804-6 nuts,
...and nothing else.
More updates soon, when I figure out exactly what I'm going to do.
Buck Wyndham
Northern Illinois
RV-8 N18XL
Last edited by BuckWynd : 08-28-2009 at 05:41 PM. Reason: Added link to other thread.
Old 08-27-2009, 09:41 PM
GAHco's Avatar
GAHco GAHco is offline
Exclamation Here, here !!
I will second that suggestion from a technical standpoint.
It is the same fastener, except the thread length is slightly longer, and it has a 6606-?? instead of a 6206-??. The materials and strengths are identical.
I probably can get the 6606-36 in qty cheaper than the 6206-36, they are a little more common.
We already have the NAS1804 nuts.
I found my last response/post from before.
http://www.vansairforce.com/communit...9&postcount=21
I don't have an 8, I think the bolt is going to be in tension,but if its' simple shear the nas1804 is overkill, if it is in tension or a combination then you can't get a better nut for the money.
Get em in the Sky!
Tom Brink Pres.
GENUINE AIRCRAFT HARDWARE Company
www.gen-aircraft-hardware.com
www.gen-aircraft-hardware.com/site_tips.asp
28th Anniversary of GAHco March, 2012
Thanks for being part of our success
Dues Paid November 2012
