How do you see vfr corridors on garmin pilot?
Av8rRob
Does anyone know how to see the vfr corridors that are on the back of TAC charts using garmin pilot?
If you are talking about the FLY charts for Class B airports, they are located in Documents. You can download them from the FAA catalog into documents. They are not geo-referenced.
So how do you see the chart legends in Garmin Pilot?
These are also in "Documents." Go to "Add," then "File," then "Catalog," "Legends." You can also find other things like the special procedures in certain Class B areas in these catalogs.
Thank you very much
Thank you, thank you very much.... Elvis
This is great. cant thank you enough for the hint.
