Van's is Hiring
Caummisar
This from FaceBook:
Help Wanted!
Van?s is looking to add a team member to our R&D Prototype Shop and Engineering group.
We are looking for a candidate who has the following qualifications:
1. Is enthusiastic about experimental aviation
2. Is organized, mechanically competent and safe in a shop environment
3. Has strong troubleshooting and problem solving skills
4. Is able to envision and fabricate prototype solutions
5. Works well as a supervised team member or solo and self-supervised
6. Is productive while maintaining attention to detail and safety
7. Enjoys working in a shop and/or office environment
8. Can lift 50 lbs, stand for prolonged periods, crawl and contort one?s self into the tail-cones and under the panels of small aircraft and otherwise not be limited by the physical demands of aircraft assembly and shop work
9. Is competent with Microsoft Office
Job duties will include but are not limited to:
1. Building prototype aircraft
2. Verification of instructions through assembly
3. Writing and proofreading kit assembly instructions
4. Fabrication of tooling
5. Maintenance of existing aircraft and aircraft components
6. Making creative contributions to product development
7. Hangar ?housekeeping? : floor sweeping, scrubbing bugs off of leading edges etc
The following is a list of attributes that would be beneficial but not required:
1. Have built or assisted with construction of a homebuilt aircraft (particular consideration to those with RV experience)
2. Have experience with composite layup and tooling fabrication
3. A&P or similar mechanical experience with GA aircraft
4. Piloting experience
5. Basic experience with CAD programs such as AutoCAD.
Email resumes to [email protected]
attention Rian Johnson
They left off "Sense of Humor"
Expert in Office, AutoCAD, Building Airplanes, and bug removal. There's that humor again.
If I lived closer . . .
Yeah, I was thinking I have an established Van's model prototype shop here in Flagstaff. Maybe they'd like to outsource?
another posting needed!
...where's the posting for:
HR administrator-
- required to sift through the thousands of applications for the OTHER R&D posting!
( frankly I didn't think Van's had a specific R&D role, doesn't everyone do that?)
oh, wait...............is this a paid position? if not, just interning, then they'd only have to deal with HUNDREDS of applications!!! :)
I don't work for VANS.
I cut and pasted the job ad from Van's FaceBook Page. I don't work for Vans. Don't send me resumes or questions about the job.
Email resumes to [email protected] attention Rian Johnson
This from FaceBook:
Help Wanted!
Van’s is looking to add a team member to our R&D Prototype Shop and Engineering group.
8. Can lift 50 lbs, stand for prolonged periods, crawl and contort one’s self into the tail-cones and under the panels of small aircraft and otherwise not be limited by the physical demands of aircraft assembly and shop work
7. Hangar ‘housekeeping’ : floor sweeping, scrubbing bugs off of leading edges etc
