Can any of you veteran RV-3 builders advise me on how to measure and adjust the length of the forward push-pull tube to make sure you have adequate travel when attached to the control stick (what is the neutral point on the control stick position - vertically level?). Also, when do you put it in permanently? I looks like it would be hard if not impossible to get in or out after the bottom seat skins are riveted on.
