Old 11-10-2020, 07:29 AM
lr172 lr172 is offline
Originally Posted by Mark33 View Post
Yes, I commented on this thread. For the reason you?re pointing out I?m installing duel relays running in parallel with each other. Each fuel pump will have it?s own relay but will also be able to be powered by the opposite relay. Each fuel pump will also be powered by its own separate circuit breaker.
Don't forget that a scheme like this will also require switches to activate each pump. You will need a method to test that the b/u pump is operational at Run up. I would also be concerned that BOTH pumps are run through one common relay. If that relay fails, you stop moving air unless there is a backup power route to the pumps. As shown in the pic, I would be concerned with that design. In theory, a failed relay should still make the NC connection, but you are banking a lot on that fact.
Old 11-10-2020, 12:43 PM
JoopSJ's Avatar
JoopSJ JoopSJ is offline
Originally Posted by 219PB View Post
Just sent you a PM
PM replied, Thank you!
Empennage, Wings, Fuse .. Done
Working on Finishing and FWF
Donation 2017. . . 2020
Chairman NVAV (EAA chapter 664 - Dutch experimental aircrafts builders)
Member EAA
Member AOPA
