Keep VAF
Going
10-23-2017, 10:38 AM
RV-14 Ultimate Gust Lock!!!!
....We need a RV-14 in so cal to test fit and bless our new gust lock on. we will give product, and be very grateful for any and all help. Thanks, Allan..
Allan Nimmo
AntiSplatAero.com
Innovative Aircraft Safety
Products, Tools & ServicesInfo@AntiSplatAero.com Southern California (KREI)
RV-9A / Edge-540
(909) 824-1020
10-24-2017, 09:02 AM
........we are still looking??????
Allan Nimmo
AntiSplatAero.com
RV-9A / Edge-540
(909) 824-1020
10-24-2017, 12:02 PM
Not in Cali, but you can send it to me in Florida. I can take pictures and give you feed back and dimensions.
I currently use a little external clip on the rudder with a REMOVE BEFORE FLIGHT flag, and a strap on the inside that goes side to side and wraps around the sticks.
10-28-2017, 06:09 AM
sometimes when you getting ready to depart from a remote location and you have family or friends seeing you off you can become distracted. such as when your Mother has to give you a box of tomatoes and a lecture about making relish during your pre-flight. it sure is nice to have the gust lock mounted inside so that you cannot depart without removing it. thanks Allan for good simple safe design. I use it all the time.
Steve Melton
Cincinnati, OH
RV-9A, Tip-up, Superior O-320, roller lifters, 160HP, WW 200RV, dual impulse slick mags, oil pressure = 65 psi, EGT = 1300F, flight hours = 900+ for all
I was born an airplane nut. I have no explanation for it.
www.rvplasticparts.com
10-28-2017, 06:18 AM
I was going to order one for my RV-8 with in flight adjustable pedals...had my credit card ready and everything. Not only was Spruce out of stock, apparently the gust lock doesn't work with my in flight adjustable pedals.
Any plans to address this?
RV-8 #81077 Super Slow Build
Dynon Skyview HDX, Titan IOX-370, Dual P-Mags, AFP FM200A FI, Whirlwind 200RV CS Prop
First Flight 11/20/2016
https://www.marksrv8.com
10-28-2017, 10:00 AM
I guess I can see it being a problem if you are parked pointed down the runway you are about to take-off on.... other than that, do people actually taxi without using the rudder?
I realize mistakes can happen but how would someone ever taxi to a runway without realizing that the rudder is locked externally?
I admit to inadvertently leaving a rudder gust lock on one time but it was obvious the moment I first put my feet on the rudder pedals.
Scott McDaniels
Hubbard, Oregon
10-28-2017, 01:03 PM
I've talked to someone who did it, even within the past couple of years. It wasn't me, but another RV pilot. Amazing the things you can miss when you're preoccupied. I agree, it's likely rare, but it definitely happens.
02-11-2021, 12:34 PM
RV14A Gust Lock
O have a new RV14A with the sticks from vans. I need a gust lock. Are you close? Id be happy to test on for you if you are not sure.
317-997-2772
Vince Ottoi
02-11-2021, 12:35 PM
RV14A Gust Lock
317-997-2772
Vince Otto
02-11-2021, 01:40 PM
Same here, waiting for that awesome gust lock for the standard 14 sticks!
RV-14A #140376
N196 (Flying)
2019 Bronze Lindy
Thread Tools |
Display Modes |
