Old 09-08-2021, 05:34 AM
Joeyo68 Joeyo68 is offline
Default 6 years down the track and getting closer.
While searching VAF for info, as we all do during our build, I found my thread from when I started on this journey 6 years ago.
Little bit of progress update.
Tail is complete, wings are done
Fuselage is built, electrical fitout is almost complete. Canopy is done. Its up on its gear.
Hung the engine a few weeks ago am finishing off the cowling. Long story with the cowl, but I got a 320 mount and cowl, and I am putting in an IO-360-B1B, with a GT 3 bladed ground adjustable prop.
So, busy doing the cut n shut with the scoop to make it fit. Really starting to look like an aeroplane now.
Been really lucky, have met some great guys, clocking up some hours flying 7s. Working towards getting this thing flying within the next year.
Running out of rivets to bang!
Click image for larger version
ID:	15583  Click image for larger version
ID:	15584  Click image for larger version
ID:	15585  Click image for larger version
ID:	15586  Click image for larger version
Joe
Flying friends RV7s
Built RV7 empennage.
Wings done
Fuselage mostly done.
Working FWF now.
4th July 2022, Phase 1 CofA issued!
5th July 2022, First flight😬😀😀😀
Old 09-08-2021, 08:16 AM
Charles in SC Charles in SC is offline
That looks great! If you have not done it lately get some time in a -7. I wish I had done it at that stage. I would have worked faster if I had known how much fun a -7 is. I had never even sat in an RV other than mine until after mine was finished.
RV 7
Old 09-09-2021, 07:08 AM
Vansrv7arob Vansrv7arob is offline
The other way of doing it that works well is 320 Mount, O360 cowl and graft inch and half ish onto the back (for vert induction O or IO360)
Regards,
Rob.
................__|__
......______(-o-)______
M: (61) 401 578 700
Old 11-28-2021, 03:16 AM
Default Milestone day, move to the hangar
Another major milestone today. Moved the fuse down to the hangar so the wings can be fitted and finish the engine hookup.
Lots of help moving.
She is in good company.
ID:	18802  Click image for larger version
ID:	18804  Click image for larger version
ID:	18805  Click image for larger version
Joe
Flying friends RV7s
Wings done
Working FWF now.
Old 11-28-2021, 07:04 AM
jcarne's Avatar
jcarne jcarne is offline
Congrats Joe, shouldn't be long now!
Jereme Carne
PPL
RV-7A Flying as of 03/2021
Old 04-12-2022, 05:44 AM
Default Got paint and wings!
More progress over the last couple of weeks.
Spent last week with my painter painting my RV, and tonight, with some local RV/pilot buddies we bolted on the wings for the final time!
ID:	24511  Click image for larger version
ID:	24512  Click image for larger version
Joe
Flying friends RV7s
Wings done
Working FWF now.
Old 04-12-2022, 11:24 AM
keitht keitht is offline
I installed a IO-360B1B from Aerosport power in my RV-7A with a Hartzell CS prop. I modified the snorkel and airbox to make the snorkel removable and used the top part of a wet suit bootee to make the air tight seal between the cowling and airbox. It works really well and make the lower cowling much easier to remove and install. Pictures are below. I also drilled a 1/4 inch hole at the back of the airbox to assist in draining the airbox after flooding the engine during a botched hot start. My empty W&B came out at 80.2 inches which is well within the normal range but further back than I was expecting. I have the O-360 mount. With the O-320 mount and a lighter composite prop you may be in about the same range.
ID:	24531  Click image for larger version
ID:	24532  Click image for larger version
Old 04-13-2022, 04:09 AM
Hi Keith,
I looked at your mod, but had enough just getting to where I am. If I remove rage spinner, it gives me about an extra 1/4” room to fit the cowl, so hopefully won’t be too bad.
Thanks for the info on your CG.
Joe
Flying friends RV7s
Wings done
Working FWF now.
Old 06-25-2022, 05:38 PM
Talking Another milestone. First engine start!
Did my first engine start yesterday. All went well. Happy Days!
ID:	27467  Click image for larger version
ID:	27468  Click image for larger version
Joe
Flying friends RV7s
Wings done
Working FWF now.
Old 06-25-2022, 07:57 PM
nohoflyer nohoflyer is offline
Congrats. Your thread immediately caught my attention as I am 74766. Three hundred behind you and trying to catch up. Nice paint!
RV-7A builder
A320 Capt at some airline
T-37/T-38/KC-135
C-177/172
Piper Warrior
2022 donator
Emp complete
Wings complete
Awaiting fuse kit
