Old 07-06-2022, 12:12 PM
Koelemon68 Koelemon68 is offline
Default POH?
I purchased a RV 7 with a O-320 (160 Hp carb) engine. I know it is experimental but one thing I missed in the prebuy was any sort of a POH. All it really has is the W&B and a 4 page document that is titled with the builders name, AC serial number and says “Operation Limitation” but nothing is filled out with any speeds. And it talks about limits during phase 1, phase II.
Looking for information on what should be in the aircraft and what you all do yourselves. I put my email below if it is easier to share.
Thank you,
Carl Koele
Ckoele at gmail.com
Carl Koele
RV-7
Fort Worth, TX
Old 07-06-2022, 12:30 PM
Bruce's Avatar
Bruce Bruce is offline
Carl,
Samples of POH’s on this site.
Home page.
Left side about half way down.
Boomer
Bruce (BOOMER) Pauley
Kathy (KAT) Pauley
RV 7A--"MISS MARIE"--- N177WD (SOLD FLYING)72742
VAF #582-----------------EAA LIFETIME MEMBER
EX -KC-135A -------------BOOM OPERATOR #3633
VAN'S FLIGHT------------#6930
RETIRED————————-Enjoying life
See you in OSHKOSH
http://www.mykitlog.com/users/index....ley&project=84
=VAF= 2006-2022 DUES PAID
Old 07-06-2022, 12:44 PM
RV8JD RV8JD is offline
It seems like you are quite new to Van's E-AB airplanes in general. This link from Van's Aircraft provides some other info that you should be aware of:
https://www.vansaircraft.com/faq-tec...g-a-flying-rv/
Carl N.
RV-8
KAWO
Old 07-06-2022, 01:16 PM
Sam Buchanan's Avatar
been here awhile
That link states "regulations require an Operator’s Handbook". Is this a new regulation, I've not seen that before.
Mel...what say ye?
Sam Buchanan
RV-6
Old 07-06-2022, 01:24 PM
Mel...what say ye?
I noticed that also, and I don't believe that is correct for E-AB aircraft. SLSA and ELSA, yes.
Here is a previous thread on the subject:
https://vansairforce.net/community/s...d.php?t=115014
Per Mel in Post #8 in the above link:
"POH is highly recommended but not required. The Operating Limitations issued by the inspector complies with the POH requirements."
Carl N.
RV-8
KAWO
Old 07-06-2022, 03:53 PM
Ralph Inkster Ralph Inkster is offline
Sounds like you are a prime candidate to follow the EAA Flight Test Manual & Test Cards process. You will really 'learn' your aircraft & the process will give you valid (for your aircraft) data to build a real POH.
https://www.eaa.org/shop/product-category?i=941&pi=926
Ralph
built a few RVs, rebuilt a few more, hot rodded more, & maintained/updated a big bunch more
Old 07-06-2022, 04:18 PM
agent4573 agent4573 is offline
While the test cards linked above are a great way to establish V speeds and other portions of the POH, I think they're only half the story. The POH should also have system architecture and emergency procedures in it. How your aircraft fails and how you should respond to it are mainly based on how it was built. If the aircraft didn't come with a wiring diagram, it would be prudent to list out the major components, which items are on which circuit breakers, etc. Having a POH from the original builder is a huge help since they know the layout the best, but if you didn't get one, you just need to spend the time to create enough documentation that makes you comfortable to go fly.
www.rv7build.com - out of date, will be updated soon
N69ER - built and flying - 2022 Bronze Lindy
Old 07-06-2022, 08:34 PM
gyoung's Avatar
gyoung gyoung is offline
The V speeds should be listed in either the Ops Limits or log book to complete Phase 1. Does your log book have the sign off for Phase 1? If so and the V speeds are not listed then it may not be proper and you may have to redevelop the V speeds. If it has not been signed off then you have other issues to complete Phase 1.
Greg
1950 Navion - flying
RV-6 - first flight 5/6/2021
1940 Rearwin Cloudster project in progress
4 L-2 projects on deck
Old 07-06-2022, 10:31 PM
Taltruda Taltruda is offline
Thank you,
Carl Koele
Ckoele at gmail.com
A POH isn’t required, however, the letter titled “Operating Limitations” must be carried onboard..
Tom
Las Vegas
RV-4 flying…
RV-8 empenage finished 10-2020
Wings Started.. 11-2020
