Keep VAF
Going
02-14-2022, 12:56 PM
How much oil
I have a 0360 in my Rv6
Seems to blow out oil I’m at 7 quarts
What do most of you put in
Danny
N15vr
02-14-2022, 01:05 PM
I put in 6 at oil change
and add a quart when it gets to 4. Usually have to add twice between changes.
Superior XP-360 and 1600 hrs.
Rusty "Rooster" Williams
N357RV RV-7A Tip Up (flying and Painted!) - 1560+ hrs.
Superior XP-360, carbureted, Hartzell 74" Blended Airfoil Prop
Grand Prairie, TX
KGPM
02-14-2022, 01:09 PM
Blow off point
I'll let the A&Ps share their number here for what's best.
I have not found the blowoff level in my airplane yet. Brand new Thunderbolt YIO-390 with Superior sump, using break in oil and prescribed running power levels to 50 hrs. I use what seems like a lot of oil compared to other claims. ~7-8 hrs/qt But have had quite a few experienced folks tell me that's about right. I have run from as low as 4.5 qts (on the stick) to perhaps 7 quarts and did not in that range see any precipitous increase in consumption. The only oil trace I can find is down #1 intake tube. Have checked that guide and can't feel any difference between it and the others.
For what it's worth.
Vincent 'Duck' Wawrzynski
LtCol USMC (Ret)
F-18/F-5/F-16, AH-1/UH-1/CH-53/CH-46, C-130/AN-2
RV-7 complete with all the gadgets
Aviation Safety/Accident Inspector/Investigator
San Jose State University Av Faculty, CFI/GFI S/M (I)
02-14-2022, 01:13 PM
My engine holds well 6qts, it’s aO-320 E3D, if gets to 5 I will add qt. Seems to burn a qt every 20 to 25hrs
02-14-2022, 01:17 PM
IO 370, I add 1/2 qt oil when it goes below 5qts to keep it between 5-5.5. Anything over that seems to blow out but I do fly some acrobatics in my -8. Engine has about 110 hrs since new and burns a qt in 10-14 hrs.
02-14-2022, 01:28 PM
New Thunderbolt YIO-390 EFII, Stock sump, W100plus since 120 hours. Now almost 200 hours. I've tried running it down to 4 qts and adding a qt along with 5 qts and adding a qt. Does not seem to make a measurable difference. Was also at 7-8 hours per qt and now maybe 8-9 hours per qt. I've known some builders as low as 6 hours per qt same engine. I'm getting some "spitting" of oil from #3 intake tube. So far been flawless. Initially was concerned about what I felt was greater oil usage than normal but now I'm hearing of several engines with similar burn rates. I had a several oil leaks around the head gaskets and took some time before I could fly it (probably less than 20 mins run time) and initially concerned I might have glazed the cylinders but now seems normal.
RV-14A QB builds, Lycoming 390 Thunderbolt arrived July 2019, Garmin avionics, Vertical Power, EFII-32 Ignition and Fuel, Whirlwind 300-72, Earth-X batteries, Parts became a real airplane 8/15/2020.
Started RV-10 Nov 2020. Empennage arrived (Built) Working on QB kits. Garmin avionics, Vertical Power, EFII-32 Ignition and Fuel, Whirlwind 3 blade, Earth-X batteries, real airplane hopefully early 2024. Paid subscriber and more. (Worth every dollar contributed).
02-14-2022, 01:36 PM
Van's run their demos between 4 - 6 quarts. I do the same.
Glenn Martin
Windsor, Ontario
1941 Tiger Moth
2017 Waco YMF-5
RV-14 Kit # 140694 - First Flight June 22, 2021
RV-14 A - Kit Ordered February 8, 2022
2022 Dues Paid
02-14-2022, 01:46 PM
I calibrated my dip stick after an oil and filter change @ 4 5 and 6 quarts.
TURBO YES =VAF= Payed Jan2022
Ed D'Arcy
RV6-A 5,400+ hrs, R-44 1,700 hrs, Helicycle traded for 33 FFR coupe, 300 young eagles flown
Stuart, Fl / East Hampton,Ct / Virgin Gorda, BVI - villa sold.
addicted pickle ball player
02-14-2022, 01:54 PM
I change with 6 qts, I'm usually right under 5 qts @ 50hrs when I do the next change. It works out nice that cases make two oil changes.
Chris Odens
West Central, Minnesota
RV-7
02-14-2022, 01:55 PM
Super Moderator
A friend at Lycoming told me to keep the oil in my O-360 between 5 and 6 quarts. Anything above 6 is subject to going overboard. You can go lower as others have noted.
Chris
Chris Pratt (2022 VAF DUES PAID)
RV-8 Flying, 900+hours
N898DK
Lycoming O-360-A1A, Hartzell CS
52F (Northwest Regional, TX)
Thread Tools |
Display Modes |
