External/internal nav and the A/P
togaflyer
When using the Touch screen for en route flight planning, the A/P will disconnect from the nav mode to Roll when you switch from external to internal navigator (and back to external). Is there a way to configure the system so it will remain coupled to the A/P nav GPS when you toggle back and forth between external/internal on the G3X touch or is it what it is. The external nav is a GTN and the autopilot is a 307.
What the Garmin expert said. It’s designed to disconnect when switching from external to internal. So this is what I do. As soon as you switch, you just need to reactivate the nav on the A/P.
