Old 04-13-2021, 06:33 AM
Walt's Avatar
Walt Walt is offline
Originally Posted by mfleming View Post
instead of starting a new thread.
Garmin says there can be no more than 10mA per pin on the GAD 27.
Garmin also doesn't publish the milliamp ratting for all of their displays. I did find the GDU-4XX are 1mA per unit for the lighting bus but could not find the milliamp rating for anything else.
Seeing that I have 7 units with lighting buses and want all of them on one dimmer...I don't want to exceed the max 10mA draw on one pin and screw up the GAD 27.
Any insights??
I can't imagine what those 7 units are?
I run 2 screens on one output, a GTN on another, CP lights on another.
Things like audio panel, GMA, GTR units really don't need dimmers, their internal ones work just fine.
I don't think you could ever get everything balanced perfectly using just one dimmer pot.
Walt Aronow, DFW, TX (52F)
EXP Aircraft Services LLC
RV7A built 2004, 1900+ hrs, New Titan IO-370, Bendix Mags
Old 04-13-2021, 07:59 AM
g3xpert's Avatar
g3xpert g3xpert is offline
Default Lighting Bus Input
Any insights??
The lighting bus inputs are typically very high impedance, most installations don't come anywhere near the 10mA limit. If you are putting 7 LRU's on one pin, we can double check just to be safe. Let us know what units you want to connect and we can calculate the max current draw the lighting bus inputs are capable of, collectively.
Justin
Garmin G3X Support
g3xpert@garmin.com
Old 04-13-2021, 09:02 AM
mfleming's Avatar
mfleming mfleming is offline
The 7 displays are:
GDU460 PFD
GDU470 MFD-1
GDU470 MFD-2
GNX375
GTR200B
GMC507
GI260
So the interconnect drawing I have from SteinAir shows all those units connected to dimmers through the GAD 27.
I never considered just having the GDUs on the dimmer and the rest operated on the photocell. You're saying that setup works OK.
If everything not on a dimmer could be adjusted with the setup mode to be not too bright at night... that could work...
Justin
Walt recommended having just the GDUs on dimmers.
But, it would seem that if the manual gives us a limit on the milliamps through a single pin, the information should be available somewhere in the install manuals. The only reference I could find was the GDUs page 26-26 highlighted in green. The other displays did not have this info that I could find.
By the way, what does that sentence highlighted in blue mean?? It seems to suggest that more than on display per pin needs some sort of regulator.
Michael Fleming
Joseph, OR
sagriver at icloud dot com
RV-7 Slider #74572
Started 11/2016
Empennage completed 11/2016 (sans fiberglass)
Ailerons and flaps completed 3/2017.
Wings completed 12/2017
Started on QB fuselage 01/2018
Sliding canopy mostly completed 10/2020
Wiring completed
Avionics harness build in progress
Donated for 2021 and so should you
Old 04-13-2021, 09:56 AM
g3xpert's Avatar
The 7 displays are:
GDU460 PFD
GDU470 MFD-1
GDU470 MFD-2
GNX375
GTR200B
GMC507
GI260
In your installation, the regulated backlight voltage reference is the GAD 27. You can use a simple rheostat to provide a reference voltage to a GDU, but you would not want to use the same to provide a reference voltage to several different units, you want to use a GAD 27 or something similar.
Justin
Garmin G3X Support
g3xpert@garmin.com
