Old 02-04-2021, 01:11 PM
alcladrv alcladrv is offline
Default Add a stick-mounted PTT
In reference to the attached document, where would I tie in a stick-mounted PTT switch?
Thanks!
Name:	Dual Comm without Audio Panel.pdf
Old 02-04-2021, 01:22 PM
bjdecker's Avatar
bjdecker bjdecker is offline
Put a momentary contact switch between the microphone tip and ground.
Brian Decker
Retired Firmware Guy and Airplane Builder
2020 RV-14 QB -- Under construction - Tailcone & Empennage Complete.
2018 RV-7 QB -- Built, Flying
2007 RV-7 QB -- Built, Drowned, Resurrected and flying
1998 RV-8 QB -- Started, Sold
1986 Mooney 205SE
1980 Mooney 231
Aided and abetted building a number of other RV's.
Old 02-04-2021, 01:24 PM
It goes to the wire labeled ‘blue’ coming off the mike jack, e.g., the one that goes to the tip of the mike plug.
