Old 08-25-2021, 03:50 PM
TASEsq TASEsq is offline
Default Finish Kit inclusions in Fuselage Kit
I have the fuselage kit coming soon and was wondering if there were any inclusions from the finish kit that would be useful or sensible to bring forward to the fuselage kit?
For instance I was thinking the tailwheel spring might be good - to allow me to finish the lower rudder fairing and also to help if I end up making a rotisserie.
Good idea? Unnecessary? Any other ideas?
___________
Trent Stewart
Melbourne, Australia
http://www.tasrv14.blogspot.com.au/
Old 08-26-2021, 04:16 AM
Mark Albery's Avatar
Mark Albery Mark Albery is offline
If you haven't already got the wing kit, you will need the W-00026 fixture in a couple of places in the fuselage build ( flap torque tube and canopy release pins). That part is supplied in the wing kit.
You may also want to consider whether to get the Tosten stick grip assemblies to substitute the bare control sticks and the tailwheel step option (I'm still waiting for that back-order).
Old 08-26-2021, 05:02 AM
Jetmart's Avatar
Jetmart Jetmart is offline
A bit of an aside. I found a saw horse instead of a 2nd engine stand on the tail worked really well. I bought two engines stands and never got around to installing the 2nd one at the tail.
Glenn Martin
Windsor, Ontario
1942 Tiger Moth
2017 Waco YMF-5
RV-14 Kit # 140694
First Flight - June 22, 2021
2021 Dues Paid
Old 08-26-2021, 06:23 AM
Thank you -
Did you install the tail spring for it to rotate around on the horse? Or did the tail just sit straight on the saw horse?
___________
Trent Stewart
Old 08-26-2021, 06:34 AM
Jetmart's Avatar
I did not use the tail wheel spring. I just set the tail on the sawhorse. I did not have the engine stand mounted in the exact center of the firewall so the tail did not rotate uniformly around a center point. I propped up the tail as required. I purposely offset the nose on the engine stand to clear the side of the fuse and the floor.
Glenn Martin
Windsor, Ontario
1942 Tiger Moth
2017 Waco YMF-5
RV-14 Kit # 140694
2021 Dues Paid
