What tools or techniques are you using to get into the roughly 2 inch space between the upper and lower wings of these metal mounts after final drilling in section 29?
There are some huge burrs I need to clean up but the standard avery hand operated debur tool with a countersink head on it is too long and just using the head only, like I've done in other tight quarters, would be tough on steel.
