I have an O-320 D2G. The oil sump has two drain plugs. One, toward the front of the engine, has a plug with safety wire and a square nut head to loosen and tighten the plug. All perfectly understandable. The rear has a recessed plug, flush with the sump, that has a hex socket that takes a 3/8 hex wrench. Photo attached. I have seen other Lycomings with a quick drain at that location. I would like to put one there because it is the lowest part of the oil sump when the aircraft is parked. Am I just asking for trouble?
