Old 08-18-2021, 12:54 AM
Michel Collet Michel Collet is offline
What is exactly GPS 35 ?
Michel
Old 08-18-2021, 08:56 AM
gmkonrad's Avatar
gmkonrad gmkonrad is offline
Default Garmin 18X gps
Michel,
The Garmin 18x 5hz GPS works for Tru-Trak Digiflight II. I would think it would also work for the ADI Pilot II. If necessary it can be reconfigured with a laptop PC.
https://buy.garmin.com/en-US/US/p/13195
Gary
Gary
RV-7 FLYING
N319GK
Old 08-20-2021, 01:22 PM
Tom @ N269CP Tom @ N269CP is offline
Originally Posted by Cth6 View Post
Without a GPS source to provide track or heading information it will fall back to the bank mode that you are seeing.
Note the heading is a GPS track heading not a magnetic heading.
You will need a GPS that provides serial output to make this set up work.
FYI. My TruTrak a/p is coupled with my Aera 660. I was unsure what heading type was displayed on the a/p. So I scrolled through the various “data boxes” on the Aera 660 and found the only data box exactly matching the a/p display was “Gnd Trk (mag)”. So, it is my impression that the a/p displays Ground Track (mag) when coupled to my GPS.
Kind regards,
Tom
RV-8 N269CP
O-360-A1A w/Hartzell CS prop on 100LL
Slick-IC+PMag ignitions
Steam gauges
EI UBG-16, FP-5, & MUX-8A datalogger
Garmin Aera 660
TruTrak ADI Pilot II (GPS coupled)
Garmin GDL39 3D ADSB-In
uAvionix Tailbeacon ADSB-Out
Infinity grip w/Matronics trim speed control
Reiff preheater system
TCW oil cooler air damper w/servo drive
AntiSplat oil mist separator
Mountain High O2D1 O2 system
Old 08-27-2021, 10:34 AM
Gary, thanks.
I am going to buy one.
Does the GPS work as it comes out of the box ?
Or is any reconfiguration needed ?
Michel
Old 08-28-2021, 12:44 PM
gmkonrad's Avatar
I believe the Garmin 18X-5hz gps will work out of the box.
BUT, check for proper input voltage, it requires 4 - 5.5 vdc.
Connect the gps #4, white, transmit data, wire to the ADI Pilot II pin 17, Primary Serial Input. Also be sure of a common ground between the gps and the autopilot.
Yes the Garmin gps can be reconfigured if needed. I needed an adapter to connect it to a laptop serial port, and software to read/configure the gps.
The adapter was made by Keyspan, the software came from Garmin.
Gary
Gary
RV-7 FLYING
N319GK
