Old 06-08-2021, 11:47 AM
Vfr1200's Avatar
Vfr1200 Vfr1200 is offline
Default Hole size
New build question
Searching for a chart on what size the center hole for a certain nut plate
Example K1000-4 nut plate the center hole get drilled to a final size ???
Iím struggling with the terminology of the bolt sizes drill sizes etc..
Old 06-08-2021, 01:25 PM
wirejock's Avatar
wirejock wirejock is offline
Default Nutplates
Originally Posted by Vfr1200 View Post
New build question
I don't recall a chart. Maybe someone will post.
For now, here's the common ones.
Nutplate=bolt=drill
K1000-06= #6=#29
K1000-08=#8=#19
K1000-3=3/16"=#12
K1000-4=1/4"=1/4"
K1000-5=5/16"=5/16"
K1000-6=3/8"=3/8"
Larry Larson
Estes Park, CO
wirejock at yahoo dot com
Donated 01/01/2021, plus a little extra.
Empennage, wings, fuse, finishing kit, now FWF
Disclaimer
Old 06-08-2021, 02:12 PM
bjdecker's Avatar
bjdecker bjdecker is offline
Nutplate=bolt=drill
K1000-06= #6=#29
K1000-08=#8=#19
K1000-3=3/16"=#12
K1000-4=1/4"=1/4"
K1000-5=5/16"=5/16"
K1000-6=3/8"=3/8"
#29 drill is too small for a #6 screw. Use a #27 or #28 drill (~ 9/64")
Brian Decker
RV-7 (Flying)
Old 06-08-2021, 02:22 PM
Vfr1200's Avatar
Default Perfect
Thanks so much will be of great help
Old 06-08-2021, 03:43 PM
wirejock's Avatar
Default Guess
I guessed. Actually, I usually put a caliper on the bolt before grabbing a bit just to be sure. I usually drill about .010 small and ream to final.
Larry Larson
Estes Park, CO
Disclaimer
Old 06-08-2021, 04:02 PM
jrock836's Avatar
jrock836 jrock836 is offline
Originally Posted by Walt View Post
Only $4565, this drill all 3 holes at once so as fast as you can move it you can have a perfectly drilled holes. Wayyyy faster than clickbond.
<Cough Cough> Up to $5200 per gun now!! Almost 5% per year! The guns are better investments than any bank CD right now.. lol....
Joe
Van's RV-12 #120566 - ELSA - N49DD
Spinks Airport, KFWS, Fort Worth, TEXAS!
DONATED
