Old 12-07-2020, 05:27 PM
bmarvel's Avatar
bmarvel bmarvel is offline
Default Urgent Heater Muff/Exhaust Heads Up!
I discovered a problem with one of the heat muffs on my -14A today. Actually, the heat muff was only part of the problem, which also involved the exhaust system. As a data point, the airplane has 700 hours on it.
I thought that both muffs fit tightly enough on the exhaust pipe when I installed them. They are held in place by bendable tabs. Today I noticed that the tabs on the inside diameter of one of the end plates on a muff had worn off. The resulting sharp edge had cut a groove into the exhaust pipe around a portion of its circumference.
I did not measure the depth of the cut but it is very definitely noticeable. I just ordered replacement end plates for both muffs and will pull the assembly apart tomorrow to have a better look at it. There may be damage to the exhaust pipe under the other three end plates but I only noticed this one in the limited time I had.
This is an area you may want to pay attention to as it is not very noticeable and could create some exhaust pipe damage before you see it. And clearly, an exhaust pipe leak into a heater muff is not a good situation.
I don't now how tightly the end plates are supposed to grasp the exhaust pipe, but certainly I intend to bend the tabs sufficiently to tighten up that joint when I install the new parts. It would be be an improvement if the end plates were designed such that they could be attached rigidly to the exhaust pipe with a hose clamp instead of via a friction fit based on how you bend the tabs.
Bill Marvel, ATP, A&P/IA
Grand Junction, CO
RV-8A N751MB -1700 hours, sold
Zenith 801 sold
RV-14A 140134, N465MM - 1020 hours and climbing
Dues paid every year
Old 12-07-2020, 05:46 PM
jeffw@sc47's Avatar
jeffw@sc47 jeffw@sc47 is offline
Default More info and pics
Good catch.
I'm looking at my exhaust pipe heat muffs and trying to correlate your description of exactly what failed. i think that I see the area that may be the part that failed.
Can you post pictures of the portion that wore off of the bendable tabs on the inside circumference of the end plates after you get into it some more?
Jeff Warren
Simpsonville, SC (@SC47 > 10nm NW Triple Tree)
RV-14A (N14ZT), Ser#140195
Contribution made 12/9/21 (USArmy 2/67-2/70)
Old 12-07-2020, 06:03 PM
bmarvel's Avatar
Yes, I'll take and post a couple photos tomorrow when I get it apart.
Grand Junction, CO
Zenith 801 sold
Old 12-07-2020, 07:25 PM
Walt's Avatar
Walt Walt is offline
I just removed a 'front' heat muff from a 14 that had failed, some of the parts had broken off and others were deformed.
Walt Aronow, DFW, TX (52F)
EXP Aircraft Services LLC
RV7A built 2004, 2000+ hrs, New Titan IO-370, Bendix Mags, MTV-9 prop
Old 12-07-2020, 07:37 PM
azflyer21 azflyer21 is offline
At only 78 hours the outer most muff on the right side did the same thing.
Kevin Lippert
RV-14A N1402 Flying 03-2020
Phase 1 Complete 07-12-2020
YouTube Channel
Build Log
Zenith 750 completed 2016 -
Sold
Old 12-07-2020, 07:46 PM
GOFT GOFT is offline
Default RV 14 heat muffs
Timely!
I found that the heat muffs keeps loosening after a few hours of flying. Tightening the "hose" clamps deformed the very flimsy/fragile endplates.
Just replacing the endplates are not an option. Did so and it failed a second time.
One solution might be to install two endplates (back to back) on each end of the muffler to beef up the surface area and strengthen the endplates so that the clamp force can be increased.
Are thicker/heavier end plates available or any other solutions out there?
Thanking a solution in advance :-)
Old 12-07-2020, 08:54 PM
czechsix's Avatar
czechsix czechsix is offline
Wonder which supplier is making the heat muffs for Vans these days, or if the design has changed. I think I had a Robbins heat muff on my RV-8A and it's got over 1000 hours on it with no issues.
Mark Navratil
Spring Hill, KS
RV-8A #80583 - built/flew/sold
RV-14A #140017 - wings/empennage/tailcone complete, fuselage in progress...
My postings on this site are my own and do not necessarily reflect the views of my employer.
Old 12-07-2020, 09:11 PM
JDA_BTR JDA_BTR is offline
Mine has 140 hours and hasn’t quite failed but isn’t very sturdy either. It’s the forward one that is the worst. I can’t tighten it because of the deformation when the clamp is secured. I’m looking forward to anyone having this problem solved.
Maybe this is better?
https://www.aircraftspruce.com/catal...at05-15249.php
Ser 140142, RV-14A flying - N1463
Ser 83825, RV-8 building - N8638?
USN Ret, Urologist, AME, Repeat Offender
Old 12-07-2020, 10:43 PM
lr172 lr172 is offline
I doubt these are Robbins, as mine are very sturdy and well designed. They do not become loose or create wear if installed properly (700 hours for 2 of them on my 6A). The posters here may want to check out Robbins wings to see if they make a muff that will fit the 390 exhaust. Probably a good upgrade idea if the posts here are indicative of the part quality.
Larry
Old 12-07-2020, 11:26 PM
rv8ch's Avatar
rv8ch rv8ch is offline
Default better muff
Originally Posted by JDA_BTR View Post
Mine has 140 hours and hasnít quite failed but isnít very sturdy either. Itís the forward one that is the worst. I canít tighten it because of the deformation when the clamp is secured. Iím looking forward to anyone having this problem solved.
Same with mine - it took quite a bit of fiddling with it to make it tight. The muff you linked to looks far better.
Mickey Coggins
http://www.rv8.ch/help-people-in-ukraine/
