I was reading this website on corrosion protection and sealing of dating surfaces.
http://www.eaa1000.av.org/technicl/corrosion/faysurf.htm
It says to seal the surfaces but doesn’t give details on what produces to use. I’ve read elsewhere that typical silicon sealant can be corrosive to aluminum. Does anyone have a recommended produce for this type of sealing?
Also, any recommendations on application? I’ve read that residue from the sealant can cause issues with painting afterwards.
