Old 07-29-2021, 09:50 AM
Anders Anders is offline
Default Numatx HTS-C3K3 - Problem solved
I have a Numatx HTS-C3K3 squeezer that has been working well since I bought it 2,5 years ago. In April this year it started to leak air from the pedal when not in use. It still worked. I contacted Numatx (hy-technic.com) and they sent a new pedal which did not help. After some more communication they informed me that the unit was out of warranty, but that I could send them the unit for repair, but I would have to carry the freight both ways and the repair cost.
I then decided to open the intensifier that I expected was the culprit. Very much so. The piston plate had ben unscrewed from the piston rod (see picture). I cleaned the parts screwed the plate back on the rod, added some hydraulic fluid and closed the intensifier.
Now works as before.
Regards
Anders
Anders Nilsson
(Norway, Saab Safir driver)
RV14 Kit #140529
Empennage done
Tailcone done
Working on fuse
QB wings on order
