Old 02-18-2013, 05:41 PM
tkatc's Avatar
tkatc tkatc is offline
Default MT prop spitting grease after overhaul
My MT metal c/s prop (MTV-15) was spitting grease at around 250 hours ttsn. Calendar months suggested an overhaul vs a re-seal so I bit the bullet and had it overhauled by an MT authorized prop shop. It wasn't cheap! Here we are 18 months later and the prop is spitting grease again, 135 hours smoh.
I LOVE this prop and it always works flawlessly but black grease on a bright yellow cowl is certainly disturbing. I dropped off the plane to the same prop shop...I wrote MT an email expressing my concerns and told them I expect them to cover the repair even though I am past the 12 month warranty after the overhaul. This thing only has 135 hours on it! And I noticed the leak about 10 hours ago, so that 125! Obviously I am bummed out. We'll see if MT steps up to the plate or not..... Stay tuned!
Track my RV7A!!
Bought my flying -7A
Building an -8! (Fuse)
Old 02-18-2013, 06:19 PM
AltonD's Avatar
AltonD AltonD is offline
How often do you grease your prop?
Hartzel will tell you, "We never overhaul a prop because of too little grease, but we overhaul plenty because of too much grease."
Alton DeWeese
N526RV RV7A Tip Up, IO360 180 W/Hartzel BA prop.
Flying ~1000+ hours since Aug 28, 2010
N4IDH
Construction Log
?The secret of getting ahead is getting started. The secret of getting started is breaking your complex overwhelming tasks into small manageable tasks, and then starting on the first one.?
?Mark Twain
Old 02-18-2013, 06:27 PM
tkatc's Avatar
MT props, at least this one, has no zerk fittings. Therefore, re-greasing is normally never required.
Track my RV7A!!
Old 02-18-2013, 06:34 PM
FORANE's Avatar
FORANE FORANE is offline
Be glad a little grease spitting is your only issue. After I got my MTV prop back from fresh overhaul the paint just started peeling off. I took it to a local auto body shop where they advised it was very easy for them to strip all remaining paint due to poor adhesion.
I don't want to berate the MT USA guys as they provided great support when I was chasing a P-120-U failure to adjust prop issue, but they definitely had some paint quality control issues when they overhauled mine.
Old 02-18-2013, 06:54 PM
tkatc's Avatar
At least peeling paint doesn't stick to your windscreen!
Track my RV7A!!
Old 02-18-2013, 09:48 PM
Wayne Gillispie Wayne Gillispie is offline
It is sad to see the declining quality of products not only in Aviation, but HVAC too. Of course another price increase is just around the corner.
Good judgment comes from experience, and a lot of that comes from bad judgment.
Old 02-19-2013, 07:35 AM
Edwardoc Edwardoc is offline
I have an MT two bladed aluminum prop on my RV-8 and it started spitting grease at about 430 hours and 72 months since it was rebuilt by MT. It was their test prop when they developed the prop for the RV-8. I have an MT Governor also and I experienced an overspeed of about 3000RPM and shortly thereafter I started noticing the grease. Had the Prop and governor overhauled to the tune of a little over $3000 and I now watch the RPMs a little closer. We were doing formation when I experienced the overspeed. Have put 50 hours on since the overhaul and all is good so far. There is no lubrication required of the prop between overhauls. Just inspection for grease leaking from the hub.
