Old 01-29-2010, 01:14 PM
jferraro17's Avatar
jferraro17 jferraro17 is offline
Opulence, I has it...
Default Priming 2 different materials
So, I've reached the point with the emp tips that I'm happy with the finish--at least I think I am.
I would like to coat these areas with primer since a final paint job is years down the road. Any suggestions on what to use? My concern is, the combination of fiberglass and aluminum in the areas that need to be coated. I'm pretty sure I can't use the self-etching rattle cans I've been using throughout the build for parts.
Thanks for any advice.
Joe
Joe Ferraro
DFW, VAF #17
SOLD
Old 01-29-2010, 01:19 PM
RV7Ron's Avatar
RV7Ron RV7Ron is offline
I'm also at this point and dont have an answer yet how I'm going to do it so I'll be interested to see what the concensus is?
Ron Duren
Mechanical Engineer
"SportAir PhD"-RV Assembly/Composites/Electrical
Denver, CO (KBJC)
RV-7 'Tip Up'
Flying!! as of 3/16/14
IO-375/WW 200G-CS/SkyView/Dual P-mags
N531R "Wablosa" Wings of Red
http://www.ronsrv7project.blogspot.com
Old 01-29-2010, 01:36 PM
apkp777's Avatar
apkp777 apkp777 is offline
I am "all ears" on this one too. My plan was to use regular (non-etching) primer on the fiberglass. However, I have a couple cans of self-etching left that I wouldn't mind using up.
Tony Phillips
N524AP, RV 9 (tail wheel)
Old 01-29-2010, 02:09 PM
Ted Johns Ted Johns is offline
If it was me, I'd use an epoxy primer like PPG DP40 or similar. Don't go wild with the amount of coverage, because down the road you will have to scuff it all with red scotchbright and give it another DP40 coat prior to the finish coats.
Most epoxy primers have only a day to a week of "open" time before the above requirement kicks in. When the primer coat is too old, the top coats don't chemically bond to it, and peeling may happen.
Dog is my co-pilot.
Ted Johns
RV9 emp & wings
Old 01-29-2010, 02:43 PM
rocketbob's Avatar
http://smartshoppersinc.com/Kirker/primers.html
Kirker Enduro prime. Etching primer, works on both aluminum and fiberglass, and is inexpensive. I've used it and really like it, lays down smooth. Equivalent to PPG DP40LF. You can get two gallons sprayable for the price of two quarts of PPG.
Bob Japundza CFII A&PIA
N678X F1 Rocket, under const.
N8155F C150 flying
Not a thing I own is stock.
RV7Ron's Avatar
Epoxy primer on both alum and fiberglass? Acid etch alum first?
What about filler primer for the tips? Would that go on over the epoxy primer?
Ron Duren
Mechanical Engineer
Denver, CO (KBJC)
RV-7 'Tip Up'
Old 01-29-2010, 03:47 PM
I don't like the idea of acid etch sitting in between built up layers, so I'd reserve it for individual parts. Built up parts I'd carefully solvent wipe and then scotchbright etch. If the parts are already alodined, solvent wipe and shoot primer.
I don't like the idea of etch primer on fiberglass, though some mfg's may be ok with it.
Fiberglass: Fill pinholes first (resin wipe or wonderfil, or ...), then epoxy prime, them filler primer as needed. If you're going to give it a full coat of urethane filler primer, and not sand through it, then no need for the epoxy primer. The main advantage to a epoxy primer under a filler primer is that you immediately see when you've sanded through, and the epoxy is a bit tougher to sand through.
PPG's optimum plan for aluminum is a thin coat of acid etch, followed by a coat of epoxy primer. Many of their topcoats are not recommended for direct application over DX1791 (their chromate based etch primer). The DX1791 largely replaces alodining by providing some chromate based corrosion protection. Yup, it turns the metal a nice light gold color. If you don't need the extra bit of corrosion protection, epoxy straight to prepped aluminum is fine.
People have been successful shooting PPG Concept straight over DX1791, but when in doubt, follow the p-sheets, that's what I say.
Dog is my co-pilot.
Ted Johns
RV9 emp & wings
